NC brake pads
Custardtart
NC brake pads
Postby Custardtart » Sat May 12, 2018 10:06 am
Can anyone recommend a brake pad for the standard NC calipers that suit the Sprint format where you do 1 out lap, 5 fast laps and a cool down?
NC1 - 2.5 opposite lock device
Lakeside 62.3
Tim_cyc03
Re: NC brake pads
Postby Tim_cyc03 » Sat May 12, 2018 10:38 am
project Mu Hc+ or Club Racer Spec.
Re: NC brake pads
Postby Magpie » Sat May 12, 2018 12:06 pm
Winmax W5's (work from cold on the street as well). I ran these for a while both on/off the track. They maybe a little dusty for some. For my track use 6 sets of W5 pads to a set of rotors. Whereas only 4 sets of W6.5's (not recommended for your use) are needed to wear out a set of rotors.
If dust is a concern then look at the W3's, again I ran these for a while on the track with no fade issues. However as my 'skill' increased the pad type changed, hence went to W5's then W6.5's.
Also consider changing the brake fluid before you go to the track, especially if its age is unknown.
WMP661 (F) WMP662 (R) (hopefully these are the right part numbers), Marty Beckton from Motorsport Brakes can confirm. http://www.motorsportbrakes.com.au/
http://www.motorsportbrakes.com.au/wp-content/uploads/2016/05/MSB-Compound-Selector.pdf
plohl
Re: NC brake pads
Postby plohl » Sat May 12, 2018 12:32 pm
You might be able to get away with QFM a1rms as well. Brakes direct sell these.
I have been using the Winmax W5s for a while now, and the 5's are passable on the street, they just won't work straight away, specially on cold mornings, so it's just something you should be away of.
plohl
Re: NC brake pads
Postby Regie » Sat May 12, 2018 12:56 pm
Hawk HP+
plenty of guys use them, awesome pad and great price
Blesif
Re: NC brake pads
Postby Blesif » Sat May 12, 2018 1:44 pm
I second the Hawk HP+
JBT
Re: NC brake pads
Postby JBT » Sat May 12, 2018 7:37 pm
plohl wrote:You might be able to get away with QFM a1rms as well. Brakes direct sell these.
Not available (or weren't a year or so ago, for the NC. Had to use HPX. Excellent low dust pad for the street but tend to fade on track day sprints at about lap four/five.
Custardtart
Re: NC brake pads
Postby Custardtart » Sun May 13, 2018 8:58 am
Tim_cyc03 wrote:project Mu Hc+ or Club Racer Spec.
These seem about double the price of the other recommendations, over $400 for a set of front and rears, is that right?
Lakeside 62.3
Re: NC brake pads
Postby Magpie » Sun May 13, 2018 10:51 am
Custardtart wrote:These seem about double the price of the other recommendations, over $400 for a set of front and rears, is that right?
Give Racer Industries a call they do sell Project Mu. Whilst not applicable to the NC they have the RC-09 Club Racer (Hyundai Excel) for $350 so the $400 sounds about right http://www.racerindustries.com.au/afawcs0161690/CATID=374/ID=16713/SID=259932590/PMU-Club-Racer-Hyundai-Excel-Cup.html
Did Motorsport Brakes give you an estimate?
Re: NC brake pads
Postby Magpie » Sun May 13, 2018 2:08 pm
Custardtart
Re: NC brake pads
Postby Custardtart » Sun May 13, 2018 8:44 pm
Thanks. Sadly they’re mostly out of stock of the NC version or it’s much more expensive when you select the NC version.
Lakeside 62.3
Luke
Re: NC brake pads
Postby Luke » Mon May 14, 2018 8:03 am
One step back.
Is the car standard or modified?
What tyres are you planning on using?
2022 BRZ 10AE
2021 GR Yaris
Re: NC brake pads
Postby Magpie » Mon May 14, 2018 8:42 am
Luke wrote:One step back. Is the car standard or modified? What tyres are you planning on using?
The OP is looking at using the car on the track, hence a pad that can handle some heat. Yes tyre choice will have an impact on pad selection, as there is not much point in having a race pad if the tyres cannot handle the braking force. The OP is also looking for A050's (other post) so I guess these will be the tyres.
Custardtart wrote:Can anyone recommend a brake pad for the standard NC calipers that suit the Sprint format where you do 1 out lap, 5 fast laps and a cool down?
For example this is a photo of when I was using Winmax W3's on the QR sprint layout... in excess of 630c this is in excess of what the W3 should be subjected to! Mind you this was because the rear was 'dragging' slightly. The key to pad selection is matching it to use and if you have ducting etc.
Front Right. Winmax W5's, Trackspeed 1.5" ducts and temp was just getting to 430c
Custardtart
Re: NC brake pads
Postby Custardtart » Mon May 14, 2018 4:03 pm
Thanks guys, I’ve researched all the suggested pads and like everything Motorsport related my choice ended up being a compromise of price and availability so I have a set of QFM A1RMS on their way from Brakes Direct.
I’ll do a quick review on my thread in Garage Chat.
Matt
Lakeside 62.3
JBT
Re: NC brake pads
Postby JBT » Mon May 14, 2018 6:31 pm
So QFM A1RMS are now available for the NC?
Return to “MX5 Motor Sport”
Users browsing this forum: No registered users and 67 guests
