SE Intake and Exhaust Upgrade.
Badbuzzard
Re: SE Intake and Exhaust Upgrade.
Postby Badbuzzard » Tue May 08, 2018 12:29 am
Street Series Cat-Back Exhaust System
2004-05 Mazdaspeed Miata/MX-5 Turbo 1.8L L4
2.5" Stainless Steel Tubing
4" Polished Stainless Steel Tip
Single Passenger Rear Exit
5 x 8 x 18" Muffler
Because this says " Passenger Rear Exit", I gather this is not applicable to my car even though the pic looks right.
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 12:32 am
Or does this mean it's a single exhaust that runs down the passengers side but tip will still protrude out the drivers rear?
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 12:34 am
Part # Magnaflow # 16639, this will fit won't it?
Postby NitroDann » Tue May 08, 2018 1:11 am
It looks like a bolt on exhaust for SE/MSM, yeah.
ManiacLachy
Engaged
Postby ManiacLachy » Tue May 08, 2018 7:59 am
If it's talking "Mazdapseed Miata", then it's the US version, which means LHD. Their passenger side is our driver's side, which is the normal exit.
I don't think there is anything that would be different under the cars between the two versions that would prevent a US spec exhaust from fitting an Australian car.
greenMachine
Postby greenMachine » Tue May 08, 2018 9:35 am
I still have the box my Magnaflow came in, let me have a look at the model number and report back.
:mrgreen:
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 10:26 am
greenMachine wrote:I still have the box my Magnaflow came in, let me have a look at the model number and report back.
:mrgreen:
That would be good thanks green machine.
Postby KevGoat » Tue May 08, 2018 5:00 pm
Badbuzzard wrote:Or does this mean it's a single exhaust that runs down the passengers side but tip will still protrude out the drivers rear?
Sounds uncomfortable ....
What's with the 4" tip ?? Seems a bit desperate.
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 6:03 pm
4"s hanging out the drivers rear does seem a bit inappropriate, like to see facial expressions.
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 6:08 pm
So I spoke to Genie Exhaust centre here in Perth and I was told I'd require an exhaust that's made for turbo cars, anything other wouldn't work properly.
greenMachine
Postby greenMachine » Tue May 08, 2018 6:12 pm
:mrgreen:
14329. Label says 4x9inches, which is probably the height by width. 3in inlet and outlet.
:mrgreen:
greenMachine
Postby greenMachine » Tue May 08, 2018 6:18 pm
Badbuzzard wrote:So I spoke to Genie Exhaust centre here in Perth and I was told I'd require an exhaust that's made for turbo cars, anything other wouldn't work properly.
Yeah right.
Depends on what they mean, if they just mean piping sized for the flow, and a muffler that doesn't choke it, OK. Anything more, and I would say they are fishing for suckers.
:mrgreen:
Postby hks_kansei » Tue May 08, 2018 6:26 pm
greenMachine wrote:Yeah right.
:mrgreen:
Agreed.
I mean, really, all an exhaust is there for is to direct the noxious fumes away from your face, and to make it quiet enough to be bearable.
Postby NitroDann » Tue May 08, 2018 6:56 pm
Im pretty sure they mean large enough and straight through. Little to no point in baffled mufflers on a turbo car. And thats how 99% of exhausts are made. Any old exhaust shop is not going to stock straight through mufflers or 2.5"+ mandrel bends.
Badbuzzard
Postby Badbuzzard » Tue May 08, 2018 7:17 pm
greenMachine wrote:
:mrgreen:
:mrgreen:
Green Machine, thanks for looking but that part # is for muffler only. I want to buy complete Cat back exhaust.
