I need to move on Patchy
before I press the button on this.
Patchy at first will be fairly standard on this with the BP-4W going in in a few weeks.
eventually this will change but to get the clutch in. I'm using the 1.6 flywheel
I'm looking at this.
https://automotivesuperstore.com.au/exe ... NrEALw_wcB
excedy Cutcj Kit Sports Tuff FMK-613 HD
feel free to suggest more suitable product.
clutch for NA6
- StanTheMan
clutch for NA6
Re: clutch for NA6
Exedy have always been good to use.
The sport tuff ones are essentially just a slightly more robust stock one, pedal feel is basically the same, you probably wouldnt pick it isn't stock.
- StanTheMan
Re: clutch for NA6
oh OK I'm hoping to get 160 whp out of it eventually.....do you feel that's adequate then?
Re: clutch for NA6
I really couldn't say to be honest.
It should be, i'm pretty sure there are a lot of people with more power than that, and using the same clutch.
Re: clutch for NA6
For 160hp all you’ll need is a cheap Exedy Standard heavy duty. Contact Direct Services and they will give you a good deal. I bought the Exedy Cushion Button Ceramic Clutch with a heavy duty pressure plate for about $500. It’s holding 250whp perfectly and it does take abuse. Easy to use on street and track. Guys at Direct clutches told me it can handle 500nm of torque. I believe I’m currently around 290nm.
Re: clutch for NA6
Try these, can make you a custom clutch based on your power and use or they can supply an off the shelf one http://www.npcperformance.com.au/
I just had one of theirs fitted (5 button ceramic), clutch same diameter as for the NA but on a BP flywheel. This may weight a little more but has less moment of inertia as it is a smaller diameter. Simply it should rev faster...
an object with 5kg mass at a distance of 0.250m from the axis will have a moment of inertia of 0.3125 kg m². Whereas the same mass at 0.275m has 0.3781 kg m². So you will have less drivetrain loss and more torque for the rear wheels...
Re: clutch for NA6
+1 for NPC. Good product, excellent to deal with and fairly priced.
- Vehicle: Non MX-5
Users browsing this forum: No registered users and 90 guests
