SE Intake and Exhaust Upgrade.
track_addict
Re: SE Intake and Exhaust Upgrade.
Postby track_addict » Tue May 01, 2018 12:13 am
I think it’s probably a bit too loud in its regular configuration. I love it since my SE is now a second car, but when I was using it everyday it did get on my nerves at times. I’m sure Dann has a solution for guys who want it to be a bit quieter for touring. Sounds great on the stock ECU though! Lots of crackles and pops!
89' Roadster - Sold
'04 SE - Sunlight Silver.
Postby NitroDann » Tue May 01, 2018 8:57 am
It's on the limit of legal, but I can fit a bigger muffler than standard too.
greenMachine
Postby greenMachine » Tue May 01, 2018 9:32 am
I'm using a magnaflow on my 3in, I reckon it is marginal, but I have my old 2.5in system as a standby, it was on the car when I transferred the rego over and I kept it for that purpose.
Can't speak for Dann's system, but mine is fine for touring.
Dann, you have email ... :wink:
:mrgreen:
Postby KevGoat » Tue May 01, 2018 11:07 am
Thanks guys. Pretty much what I imagined it'd be like.
Dann, I figured you'd be able to pretty much work it out to suit. I guess the other question is if a 2.5" would be better, or even if it's worth it at all??
Sorry ... prattling on ... distracting myself from some sudden bad health issues that cropped up recently for my wife.
Postby NitroDann » Tue May 01, 2018 11:26 am
If volume is a serious concern I would taper down to 2.5" at the rear muffler and use a very large body 2.5", the performance will be the same and the volume will be pretty low. Smaller pipe works ok on the very rear because the gases are cooling and shrinking as they travel down the exhaust.
CrazyRacer
Postby CrazyRacer » Tue May 01, 2018 9:22 pm
NitroDann wrote:If volume is a serious concern I would taper down to 2.5" at the rear muffler and use a very large body 2.5", the performance will be the same and the volume will be pretty low. Smaller pipe works ok on the very rear because the gases are cooling and shrinking as they travel down the exhaust.
Hmmm, that might be a solution for the complaints I'm getting from the passenger seat.
Any particular 2.5" muffler you'd recommend Dann?
Postby KevGoat » Tue May 01, 2018 9:35 pm
Sounds like a good compromise. So would this still give a nice sporty "rorty" note? I don't mind a bit more volume than stock, just don't want it to become over intrusive on long drives. Interestingly, just earlier today, I noticed that from outside my car my mostly stock system sounds really very ordinary! Hadn't ever heard it go down the road before and it's so quiet! Sounds way sportier from inside than it does from outside!
Postby NitroDann » Wed May 02, 2018 12:32 am
"Is this taco too spicy?"
You get what I am saying right? I could literally tell you how many decibels it would be (about 86-87@4000rpm, 1.5M distance from tailpipe) But I cannot tell you if that level suits your taste.
Postby Okibi » Wed May 02, 2018 12:46 am
I asked Dann to build me a varex muffler, it is fantastic for stealth mode and motorsport use. :mrgreen:
Postby KevGoat » Wed May 02, 2018 11:01 am
NitroDann wrote:"Is this taco too spicy?"
Yeah sorry Dann ... like asking will this car suit me, will I be happy with these coilovers, what should I wear today!!?? Have good info now anyway, but probably best I divert away from this for a while until I'm thinking clearer. I mentioned some stuff going on, and tbh this forum is really helping me as a good distraction when I need it ...
Badbuzzard
Postby Badbuzzard » Wed May 02, 2018 11:38 pm
Do people install the MAC 3 port Solenoid even on an OEM ECU or generally only if you run aftermarket ECU? And just to confirm, this is the item at the front of the rocker covers?
Postby NitroDann » Thu May 03, 2018 10:31 am
Stock with oem ecu. MAC with standalone ecu.
They dont flow the same amount of air at the same duty cycles so the ecu needs to be setup exactly right for the right valve.
SKYHI
Postby SKYHI » Thu May 03, 2018 10:54 am
Welcome to the SE club and the addiction to modding :)
I bought an SE with the basic intake, MBC, intercooler and exhaust mods already on it, and it was a lot of fun. I eventually took the car to Dann for an ECU, injectors and intake upgrade amongst other things, and it has become a much better car, although my wallet is also considerably lighter :)
If you wanted to go down the path of modding it in stages, I happen to have the AEM CAI that came off my car for sale.
Good luck with it all.
Badbuzzard
Postby Badbuzzard » Thu May 03, 2018 12:53 pm
Thanks for the feed back on the Mac. TCR, can you message me a price for the cai and any pic of it either installed or out of car. Does it have a box or shielding of some sort?
SKYHI
Postby SKYHI » Thu May 03, 2018 4:32 pm
Badbuzzard wrote:Thanks for the feed back on the Mac. TCR, can you message me a price for the cai and any pic of it either installed or out of car. Does it have a box or shielding of some sort?
All the info is in my For Sale advert on this forum :)
viewtopic.php?f=44&t=76524
