I've searched everywhere for the spring rates for stock 2 yellow dot springs (rears).
I believe they from either late (96 or 97) NA8 or early NB8A.
regards..
2 yellow dot stock spring rate
6' 7" red tardis owner (spacious 89 NA8 clone) and cleaned up 92HZ SBY.
Re: 2 yellow dot stock spring rate
Off the top of my head, can't link two white dots or two yellow dots to specific models or years, but following might be of interest:
manga_blue wrote:Early NA6 164/97 lb/in with 19/12 mm sways
Later NA6 154/94 lb/in with 19/12 mm sways
Std NA8 154/94 lb/in with 19/11 mm sways
NA8 R package 154/94 lb/in with 20/11 mm sways, but that might have been the US version only
All NB 162/118 lb/in with 22/11 mm sways
NB Mazdaspeed 215/158 with 23/14 mm sways (presumably the same on the AU delivered SE?)
Just going on those figures alone the first model NA6s had the sportiest handling (lowest FRC of 58.9%) then they got progressively worse from there until you got a Toyota Corolla-like 66.9% with the stock NB.![]()
PS divide lb/in by 55.88 to convert to Kg/mm
Following seems to be commonly referred to on the big forum: http://www.puppetmaster-robotics.com/Mi ... prings.htm
But I note there are a few other posts on there with potentially relevant info:
https://forum.miata.net/vb/showthread.php?t=606489
https://forum.miata.net/vb/showthread.php?t=480971
https://forum.miata.net/vb/showthread.php?t=354382
https://www.google.com/search?q=mx5+spr ... 53&bih=572
Thanks for your reply.
My research picked up all but your last reference. however that reference mentions 2 yellow dot as front springs from 2001.
Mine are definitely rears. I know the factory data becomes scarce after 1994.
Its not a big deal but knowing would save me replacements as they are in excellent condition.
You know you can work this out yourself too? e.g. 2Kg/mm springs will deflect 1mm when you put a 2Kg load on it. What I've done in the past is clamp the bottom ring of the spring in a vice and hang weights on a cord passing down through the middle of the spring. Best results come if you pre-load and measure with about 10Kg then measure deflection with an extra 20Kg.
