SKYHI
Postby SKYHI » Tue Apr 10, 2018 10:21 am
Congrats on the PB Mark.
Didn't realise it was Dylan driving the 86. Certainly wasn't a great idea by the driver of the Pulsar to drop straight onto the racing line when exiting the pits.
Hope the gearbox issue is a easy fix.
Postby Lokiel » Tue Apr 10, 2018 12:01 pm
ManiacLachy wrote:Got it. I wasn't even aware of the symptoms, other than "gearbox issues". Hopefully it's easily sorted. General consensus is, it's easier and cheaper to replace the 6-speed gearbox than fix it.
... and less hassle in the long run to simply replace it with a BMW gearbox - Aisin 6-speeds SUCK!
https://kmiata.com/collections/transmission-upgrades
https://www.miataturbo.net/suspension-brakes-drivetrain-49/k-bp-engine-bmw-e36-e46-transmission-upgrade-92865/
Daffy
Postby Daffy » Tue Apr 10, 2018 3:32 pm
If (and when needed), I think I will move this way, I’ve been reading up a bit about it. The gearbox is the reason why so far I stay just south of the 400hp.
I’m so keen to see this years efforts with you and the new Racepak team hook up Magpie- hoping to catch up with you soon!
viewtopic.php?t=73496
Postby Magpie » Sat Apr 14, 2018 8:25 am
Gearbox issue found....
The clutch snapped a band hence would not release fully... more than likely caused by a high RPM down change... Really need to work on the rev matching down change.
Ipswich Gearbox Repairs has given me some options, and the car will be having a custom clutch built that will hopefully also be less mass. The flywheel needs a closer inspection as there is some heat damage.
This has been in the car for almost 4 years and 10,000 hard km's
Good decision to call it quits when I did. Was asked if I heard anything. My response was it is over 110db in the cabin and I wear earplugs, so no.
Postby Magpie » Sun Apr 22, 2018 7:31 pm
Car back home, has a new 5 puck ceramic (15mm dia smaller) clutch and flywheel. A few other jobs done (remote clutch fill point, rear main seal and turret gasket).
Had big plans this weekend, but decided to spend it doing work instead :( However did get some more jobs ticked off...
- Remote jump start point (0 AWG wire with 175 amp Anderson plugs).
- HANS harness, old harness expires this year. Must thank Andrew for popping over to say high and helping with the seat removal for the harness install.
Postby Magpie » Sun Apr 29, 2018 8:30 am
Lighter hardtop (14.1kg sans mounts and rubbers) being painted
Mariner blue on the outside
Ford shockwave blue on the inside
SKYHI
Postby SKYHI » Tue May 01, 2018 10:46 am
Is this one of the new ones Lightyear is making or an older version?
Postby Lokiel » Tue May 01, 2018 12:28 pm
Magpie wrote:Lighter hardtop (14.1kg sans mounts and rubbers) being painted
Paint some clouds and maybe some flying birds on the inside, a-la Michelangelo in the Sistene Chapel, and you'll feel like you're still topless!
http://paintwithlen.com/how-to/paint-clouds/
Postby Magpie » Tue May 01, 2018 12:57 pm
Lokiel wrote:Paint some clouds and maybe some flying birds on the inside, a-la Michelangelo in the Sistene Chapel, and you'll feel like you're still topless!
Now that is a great idea!
ManiacLachy
Engaged
Postby ManiacLachy » Tue May 01, 2018 1:49 pm
Genius! And you know what kind of birds should be painted, right?
Postby Lokiel » Tue May 01, 2018 2:12 pm
Do you WANT him to crash??? - eyes ahead, NOT up!
Postby Magpie » Tue May 01, 2018 3:00 pm
I have sent an email... https://www.gumtree.com.au/s-view-details.html?adId=1181751731
I do like HR Geiger, something like this.
I could use it for sponsors...
However I am open for suggestions :)
Postby Magpie » Wed May 02, 2018 7:38 pm
YES, going to WTAC 2018!
Daffy
Postby Daffy » Wed May 02, 2018 9:31 pm
Magpie wrote:YES, going to WTAC 2018!
:mrgreen: :mrgreen: :mrgreen: :BROADY:
ManiacLachy
Engaged
Postby ManiacLachy » Thu May 03, 2018 7:40 am
Awesome, congratulations!
:NA6:
