Globe holders front parkers NA6
adelaide_paul
Postby adelaide_paul » Sun Apr 01, 2018 10:59 am
I went to change my front parker globes and found the globe holders for the wedge T10s damaged
Having some difficulty getting new or second hand globe holders, any advice would be appreciated
RileyR
Re: Globe holders front parkers NA6
Postby RileyR » Sun Apr 01, 2018 11:01 am
Same problem.
I had to silicone one of them in place
Sent from my SM-G900I using Tapatalk
1996 BRG NA8
Postby hks_kansei » Sun Apr 01, 2018 8:36 pm
head to a wrecking yard and have a look around.
Would not be shocked if they're the same as used on the 323, laser, and probably a heap of other Ford/Mazda models from the area.
Example, NB foglamps are the same as on a Mazda Tribute or Ford Escape.
Plus, grabbing bits from lasers/323 means you dont cop the "MX tax"
Postby manga_blue » Mon Apr 02, 2018 2:16 pm
Alternatively you can buy new t10 bulb holders from most auto shops. For example Supercheap carry them for $8.50 each. Then you just have to join them to the old loom and maybe spot silicone them into the lens.
adelaide_paul
Postby adelaide_paul » Tue Apr 17, 2018 8:40 pm
Tried all the auto accessory stores and a couple of wreckers. The holders appear unique. I bought these
http://www.autolinkmx5.com/sidelight-bu ... 9101-p.asp
adelaide_paul
Postby Mr Morlock » Wed Apr 18, 2018 1:08 pm
manga may be right. But It was common for lamp makers to design their own were base bulb holders i.e. they fit into the housing but turn to lock features and thickness of housing etc may not be interchangeable. I think the bulb holder with the pig tails is good solution .
adelaide_paul
Postby adelaide_paul » Wed Apr 18, 2018 8:00 pm
There are holders available that appear similar but are different sizes, My old ones were held on with silicon, not ideal
