Lightyear's Black endurance racer
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Re: Lightyear's Black endurance racer
Postby lightyear » Mon Mar 12, 2018 10:43 pm
Thanks, the wing bolts just under the 1/4 panel (the part where the bumper meets the panel) the bolts would be covered by the rear bumper if I had one on. That way you can take it off and not have holes visible in the rear 1/4. I will make a new one, but go straight up next time. Then I can run a wider wing.
mx5002
Postby mx5002 » Tue Mar 13, 2018 9:36 pm
Very smart! Will you be running at winton on the 14th of April with aroca/mx5 club? Would love to check the car out firsthand
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
lightyear
Infinity & Beyond
Postby lightyear » Wed Mar 14, 2018 6:22 am
Is that the Victoria vs NSW round? If so most likely. Oh, and it will be the fastest car there, I hope.
I am making some changes. Not a lot- built motor, turbo, diff, box, clutch, flywheel, suspension, aero, roof, boot and maybe the bonnet.
mx5002
Postby mx5002 » Wed Mar 14, 2018 6:20 pm
That's the one.. nsw v Vic. I'm Looking forward to having a drive at winton! Your the only person that would say that's not alot.. It's taken beavis 30 videos to do that :lol: :lol:
GREEN ITB'd NB8B
Marulan 47.01
lightyear
Infinity & Beyond
Postby lightyear » Thu Mar 15, 2018 1:13 pm
I decided to leave the car NA, it will end up being unreliable for endurance races unless I spend big dollars on more upgrades. So the turbo running gear will go back in the red NA.
Instead I will just do a new fastback in carbon fibre, and a new aero kit. Then throw some new R specs on. Should be good for a 1:49 or under at the island.
lightyear
Infinity & Beyond
Postby lightyear » Sun Mar 25, 2018 8:13 am
I have basically dedicated every night working on this car in the garage. It's getting an aero makeover. I entered the Vic time attack street class with the red NA, but there was too much work to get it ready (it would have been competitive). So I decided to do a bit of an upgrade on this car and enter in the modified class up against 1000kw skylines. At least I get to run R specs. There is no way I will be able to win, but I may as well see how fast I can get an MX5 to go with a stock 1.8l motor. I am aiming for a 1:48. The fastest cars will do a 1:35, so I am going to be way off the pace.
I traced the shape of the old splitter, and cut out a new one in a special lightweight plywood. The area on top of the undertray that sees no airflow got hit with the router to trim some weight out. I cut the bumper and added some alloy sheet to make the airdam and make the "ceiling" and after many many rivets it was done. The radiator is fully ducted with foam seals, so the small opening should be plenty.
lightyear
Infinity & Beyond
Postby lightyear » Sun Mar 25, 2018 8:18 am
The rear uprights/enplates are made in carbon fibre. I didn't take a pic yet. But it's the same size as the green outline. The wing is the full width of the car.
mx5002
Postby mx5002 » Sun Mar 25, 2018 2:47 pm
That front end is super aggressive!
If any consolation the car is going to look like it'll beat those 1000hp cars.
How wide was the old rear wing in comparison?
GREEN ITB'd NB8B
Marulan 47.01
Postby Okibi » Mon Mar 26, 2018 12:05 am
Awesome Dave
SKYHI
Postby SKYHI » Mon Mar 26, 2018 12:34 pm
Nice work. Really need to get my head around which cars you have and what you're doing with them these days. Lost touch a bit :)
lightyear
Infinity & Beyond
Postby lightyear » Mon Mar 26, 2018 6:39 pm
Yes, it's a bit hard even for me to remember.
I painted some bits. Will take a pic when it's all together. But for now here are 2 pics.
ianoz
Postby ianoz » Mon Mar 26, 2018 8:46 pm
thought I'd seen that paint scheme before...
NA6 '89 red, NB8B '01 silver
Postby Magpie » Tue Mar 27, 2018 7:56 am
The wing end plates are also a defacto sharkfin style.
lightyear
Infinity & Beyond
Postby lightyear » Tue Mar 27, 2018 10:50 pm
So many late nights working on this car. But it's starting to take shape.
Postby Okibi » Tue Mar 27, 2018 11:01 pm
Looks awesome :twisted: , love the white in the boot.
