[url][url=https://flic.kr/p/FKTFeg]
NitroDann wrote:An intercooler which is not heat soaked is very good at keeping IAT within 10*c of ambient. Heat soak sensor readings are typically 20-30*c higher and therefor the IAT curve matching ideal gas law tapering to rich at the very high end is a good workaround in my opinion.
Red_Bullet wrote:Here is another theory from Miata Turbo. It's to do with injector heatsoak. At 30 degrees C the injector compared to 100 degrees C. At 100 it takes 100uS longer to open than at 30 degrees C. This makes the actual deadtime longer hence cutting total fuel supply by around 10% at idle. Opening time increases because of the increased resistance of the injector coil. Apparently it goes from 15 ohms at 30C to 19 ohms at 100C.
This might explain at least some part of the hot start issues.
https://www.miataturbo.net/ecus-tuning-54/injector-current-trace-shows-slower-opening-when-hot-67534/
Red_Bullet wrote:Maybe just try to ASE our way out of it, more fuel and longer taper maybe. No doubt though you've already tried that.
Red_Bullet wrote:. I've already had a lambda sensor fail once. I put it down to sitting for long periods heated before starting the engine, condensation or whatever when cold, I suspected thermal shock got it.
Locutus wrote:It would be simpler to just rewire it to power on only when the key is in the "ON" position.
