89 NA6 - should there be a rubber boot around the indicator and wiper stalks?
twr7cx
Postby twr7cx » Thu Mar 22, 2018 10:22 am
Should there be a rubber boot for the indicator and windscreen wiper boots on my JDM 89 NA6 or is it meant to just have the open gap?
If so, any recommendations on where to reasonably source replacements?
Re: 89 NA6 - should there be a rubber boot around the indicator and wiper stalks?
Postby hks_kansei » Thu Mar 22, 2018 10:58 am
There certainly wasnt a big rubber boot over the stalk ends etc.
I seem to recall it either having just a flat piece of rubber with a slit cut into it, or maybe little brushes.
Either one did minimal at actually stopping dust getting in, since the cover is open at the back, and front where the wheel does.
They really just stopped bigger bits falling in there, but by it being vertical, gravity stops most of that too.
Postby 93_Clubman » Thu Mar 22, 2018 12:09 pm
FWIW, no rubber around the stalks of my 1993 NA8 owned since 2004. Fairly sure the 1989 NA6 I had from 1990 also had no rubber around the stalks.
Postby bruce » Thu Mar 22, 2018 12:20 pm
No booties.
twr7cx
Postby twr7cx » Fri Mar 23, 2018 3:00 pm
Cheers for the replies. Must of been a weight reduction thing leaving them off!
Postby hks_kansei » Fri Mar 23, 2018 5:47 pm
twr7cx wrote:Cheers for the replies. Must of been a cost reduction thing leaving them off!
Fixed for you.
Users browsing this forum: No registered users and 133 guests
