NC 2.0 to 2.5 swap
RaceTech
NC 2.0 to 2.5 swap
Postby RaceTech » Sun Mar 18, 2018 1:22 pm
Hi Guys,
Looking at swapping out my 2.0 for a 2.5 in my NC prod sports racecar.
Can anyone give me a idea on budget required to do the swap?
I’ve noticed a few donor engines for $800-1500 on eBay.
I already have supporting mods currently fitted to my 2.0 but would look at the EcuTek software for tuning.
Cheers!
Re: NC 2.0 to 2.5 swap
Postby bruce » Sun Mar 18, 2018 1:41 pm
Boyracer recently advertised and sold such a race car - you missed it.
There's also a recent-ish thread about a guy who did it to his street car (first two engines he got were duds). Clubman93 (the Oracle of Info) will know where that is...
Postby 93_Clubman » Sun Mar 18, 2018 2:26 pm
bruce wrote:also a recent-ish thread about a guy who did it to his street car
viewtopic.php?f=79&t=67063
And IIRC, Nuddy has also done it even more recently, but not sure if he's provided detail: viewtopic.php?f=57&t=75248
Postby bruce » Sun Mar 18, 2018 2:39 pm
Thank you Oracle.
Postby Regie » Sun Mar 18, 2018 7:22 pm
if you can swing a spanner you be able to do it cheap.
If not, some people have payed around $8K for the conversion
RaceTech
Postby RaceTech » Sun Mar 18, 2018 9:16 pm
Thanks for the info guys.
$8000 fitted seems a lot for what is essentially labour only and the engine is a drop in.
This is what I am trying to work out....
If a engine is say $1200 surly there is not $7000 in labour??
Postby NitroDann » Sun Mar 18, 2018 10:15 pm
You ever built an engine and put it in the wrong car and tuned it up all running perfect and warrantied it before, right before paying the rent power insurance and the tax man? It adds up.
Postby bruce » Mon Mar 19, 2018 8:54 am
$1200 sounds too cheap for a good engine.The first guy who did it got two dud engines initially, only discovered after installation (multiple engine removals required).
Custardtart
Postby Custardtart » Fri Apr 20, 2018 2:57 pm
Guys I’m about to go through this. I paid $500 for an alleged 50k km engine - I’m feeling worried :D
Anyone got a parts and suppliers list? I already have an upgraded header and a new clutch on the 2.0.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Postby Regie » Fri Apr 20, 2018 8:57 pm
search and you will find :D
Custardtart
Postby Custardtart » Sun Apr 22, 2018 8:46 am
Regie wrote:search and you will find :D
Thanks Regie, i saw that and whilst it’s a good list I was hoping there might be some local Aussie suppliers.
I’m assuming you can use the 2.0l ecu?
Appreciate that the ECU-tek tune does give a lot of HP but it’s also not cheap.
Lakeside 62.3
Postby Regie » Sun Apr 22, 2018 2:19 pm
2.0l ECU can be used, buy you WILL need to have it tuned for the 2.5. So factor in $1K max for licence, tune, cable etc etc
Postby bruce » Sun Apr 22, 2018 2:55 pm
If u Engineer it add a minimumn $1000 (or easily double that).
Custardtart
Postby Custardtart » Mon Apr 23, 2018 8:58 am
bruce wrote:If u Engineer it add a minimumn $1000 (or easily double that).
Having had a look at the Qld transport website it looks like this engine swap doesn’t need engineering.
Lakeside 62.3
Postby bruce » Mon Apr 23, 2018 11:51 am
Ah, Qld, anything goes! Just a cheap mod plate maybe?
