Check this <1min video explaining how IAT sensors can get heat soaked if theyre installed inside your engine bay.
NitroDann wrote:The sensor is being soaked by the material it is screwed into mostly.
ManiacLachy wrote:Red_Bullet, that sounds like it's injector heat soak. Try cranking up your ASE and extending the time for >90* starts. Also, having EGO on helps add fuel to get your AFRs in the ball park.
