NA6 Exhaust Manifold Gasket composite type - 2 required?
twr7cx
Postby twr7cx » Fri Feb 02, 2018 10:09 pm
Grabbed an exhaust manifold gasket today as I just purchased a used set of headers that I intended to install today but ended up being washed out by rain. The gasket is a composite type but strangely two identical gaskets are in the package - do both get used or only one?
StillIC
Re: NA6 Exhaust Manifold Gasket composite type - 2 required?
Postby StillIC » Fri Feb 02, 2018 10:15 pm
I believe it will be a multi-layer gasket and all layers are used (and normally joined together). If you actually have received 2 gaskets that's a win for you, but I doubt it.
Postby hks_kansei » Fri Feb 02, 2018 11:53 pm
Those dimpled gaskets are a single gasket, only one is used.
I think they've stuffed up and accidentally put two in.
Personally I prefer those style gaskets to the OEM steel ones (which are multiple layers)
the dimpled ones seal better and dont need the same 100% clean and dead flat surface that the OEM does. Even if there's a few small marks or a small warp the dimples ones will usually seal.
