anyone fitted quickrelases to the NA bumper?
shirtz
Postby shirtz » Thu Jan 18, 2018 1:29 pm
my na is stock height with a lip and I already cant get a jack under it. its only going to get worse when I get coilovers! ive seen Bevis do quick release pins on his NB, but has anyone done it on their NA?
ie
http://beavismotorsport.com/store/quick ... latch.html
or those rubber band ones..
shirtz
Re: anyone fitted quickrelases to the NA bumper?
Postby shirtz » Tue Jan 23, 2018 12:44 pm
anyone? surely this is not just a problem for me!
Postby bruce » Tue Jan 23, 2018 1:29 pm
People buy a low profile jack.
Fitting quick releases seem a bit dangerous. You don't want your bumper falling off as you drive along, or even if you have a small nudge.
smy0003
Postby smy0003 » Tue Jan 23, 2018 2:41 pm
What Bruce said, they also look awful and require you to drill holes in your bumper and wings. Even with the quick releases it will still be a pain to undo all the other bolts every single time you need to raise the car.
Buy a Costco Arcane (?) low profile jack, and get some wooden ramps if you need that little bit of extra clearance.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
shirtz
Postby shirtz » Tue Jan 23, 2018 2:42 pm
thanks guys. have the Costco jack but gets stuck on the front lip. will have to knock up some wood ramps...
ManiacLachy
Postby ManiacLachy » Tue Jan 23, 2018 2:49 pm
I'm lowered a little, but even with a low profile jack I have I can't get to the front jacking point with the car on it's wheels. I use a crappy Supercheap jack on the pinch weld to raise one corner off the ground, then using my low profile jack I can get under the front. The extra step doesn't add much time.
greenMachine
Postby greenMachine » Tue Jan 23, 2018 7:44 pm
Don't be a wuzz Lachy, give the man a link to your ramps thread :wink:
:mrgreen:
shirtz
Postby shirtz » Wed Jan 24, 2018 8:50 am
greenMachine wrote:Don't be a wuzz Lachy, give the man a link to your ramps thread :wink:
:mrgreen:
haha now im curious!
but yeah, the raise one side method or get wood ramps seems to be the best thus far.
ManiacLachy
Postby ManiacLachy » Wed Jan 24, 2018 9:17 am
:mrgreen:
My ramps thread? I do have some wooden ramps, but I don't think I've discussed them. Even using them to get the car up slightly I still need to jack from the side, the low profile jack's "hump" is too big to fit under the lip and I can't see what what I'm doing anyway. Maybe I need to add some extra height to my ramps.
greenMachine
Postby greenMachine » Wed Jan 24, 2018 1:03 pm
:mrgreen:
Bummer! It was Rocky's thread I was (mis-)remembering 8)
Ramp-age
:mrgreen:
Users browsing this forum: No registered users and 177 guests
