Can anyone enlighten me?
Any bits of black trim got a pretty-up as well.
I’ve got this 1960’s boat antenna. I’d like to find a way to fit it.
It’s getting closer!!
Gladiator wrote:
Magpie wrote::
That dash looks out of place, get rid of it!
Lokiel wrote:Magpie wrote::
+1
The gauge faces should be orange/gold to go with the "Sexual Chocolate" theme
(Bronze rims too)
- You can tell everyone your car's a "Ferrero"!
As for the spare female plugs, your best bet is probably to use wriring diagrams and the wire colours to figure them out if no-one else can help:
http://neomiata.com/garage/index.php?path=Wiring+Diagrams%2FWiring+Diagrams+1990-1996/
https://www.miataforumz.com/1990-200-Miata-Wiring/90how.pdf
https://www.miataforumz.com/1990-200-Miata-Wiring/90diag.pdf
https://www.miataforumz.com/1990-200-Miata-Wiring/90sys.pdf
... lots of reading there (start by writing down the wire colors on each connector)
Magpie wrote:Fabricate a fitting something like this for your 'boat' antenna?
Magpie wrote:Still it needs a nautical touch to fit in with your past.
