A NB8B Turbo progress.
IanR
Vehicle: NB8A - Turbo
Re: A NB8B Turbo progress.
Postby IanR » Mon Jan 15, 2018 8:43 am
Thanks to Lokiel! :D :D :D these arrived in the post,
I first tried the medium boost Borg Warner actuator, which is rated with a minimum boost setting of around 9psi. Instantly the difference between the old and new actuator is felt, making nice smooth power all the way to redline.
Using the locking nuts on the actuator rod I could add pre load to the bw spring to raise the opening threshold (which raises the peak achievable psi limit as well) OR fit the good looking turbosmart unit which allows for swapping the internal springs for a higher minimum boost setting. I chose the 12psi setup as that gives the dyno tuner a range of 12-24ish psi to play with, should be enough!
Back to Anthony https://www.facebook.com/tunedbyanthony/ for the full psi tune. My goal for the tune is based on the limitations of the parts I am using. At this point I am keeping the very quiet (81db) 2.5" exhaust (3" dump into 2 1/2" at down pipe) as I spent good money on the euro4 cat and I am happy to draw out the process with this car, plus I am interested to see how quick it can be at this fully engineered and legal state. So between running 98 and a very restrictive exhaust I am hoping for as close to 300whp as possible, the turbo will run the boost but knock will be an issue on 98, not helped at all by back pressure from the euro4 cat etc....
I made up up a little kit to test how much oil vapor was being generated under full load as the silver car used std pistons and had significant blow by pumping large volumes of oil through the catch can setup, it was a real issue that even caused the ms3 map sensor to get clogged with oil residues. This time its something I am watching more closely.
Here are the results, there are two tunes over lapped for the picture, one is the "low boost" 11psi wastegate tune triggered using the fog light switch near the drivers door. The second set of lines is the full gas tune, limited by some knock creeping in, we spend lots of time with the ignition map making it safe.
Out on the street it feels super fun, I could only do half a dozen squirts before the egt probe nut worked loose and came off leaving me with a noisy drive home with a leak out of the hole where no 2 cyclinder egt probe was... off to get some end caps...but...the car feels very playful and comes on with a very real urge the sound is delicious.
mx5002
Postby mx5002 » Tue Jan 16, 2018 7:26 am
My car makes half that! Must be awesome to drive!
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
ManiacLachy
Postby ManiacLachy » Wed Jan 17, 2018 8:15 am
What are your impressions of the EFR6258 vs the Garrett 2860RS? People say the EFR should spool sooner make better transient response and be all around better, but it's hard to pick the marketing from real life sometimes. And you're someone who's dríven both now.
IanR
Postby IanR » Wed Jan 17, 2018 9:14 am
Good question Lachy, obviously there are a few differences between my silver 2860rs car and this efr car, mainly the 3” system vs 2.5 and that the gt was running e85. That said there are a few key points which are clear to the this driver. The efr is better.
Is spools up quicker and makes more boost faster, it also sounds more alive. Even though the green efr car is making 45whp less than the e85 gt car it comes on with the same level of kick. If/when I go 3” and e85 the efr will be ridiculous in the top end far surpassing the 2860rs.
99% of my driving is at partial throttle, the turbo responds as if you were pushing it harder... but your not using more than 1/5th throttle... but then with the foot flat the torque response is more impressive than the numbers show. Not that 280whp is not impressive to drive but the way it goes from 100whp to 200whp in a moment is what really excites.
ManiacLachy
Postby ManiacLachy » Wed Jan 17, 2018 9:27 am
Thanks Ian! EFR, one day :mrgreen:
IanR
Postby IanR » Wed Jan 17, 2018 10:02 am
ManiacLachy wrote:Thanks Ian! EFR, one day :mrgreen:
Shame it will be all the plumbing bits at the same time, exhuast manifold, turbo intake setup, dump pipe, possibly oil/water lines... new clutch, wheelie bar, botox for your face so you can go to work still!
IanR
Postby IanR » Wed Jan 17, 2018 10:08 am
mx5002 wrote:My car makes half that! Must be awesome to drive!
I need some helps to keep up with you on the track sir... even then i'd struggle... track day not too far away I hope.
ManiacLachy
Postby ManiacLachy » Wed Jan 17, 2018 10:14 am
It's the built long block required to put it down that gives me nightmares! If it was just plumbing and a turbo I'd be making plans already.
IanR
Postby IanR » Wed Jan 17, 2018 10:21 am
Ahh I'm hearing you, much silence and eyes down head nodding...
Postby KevGoat » Thu Jan 18, 2018 12:55 pm
I live my power dreams vicariously through threads such as this one ... saves me much $$$, explanations, running, ducking and weaving :roll: :mrgreen: ... Learn a lot from them too. Though they do have some tendency to dissolve resolve :? Not sure I want a whole lot more power from mine ( :shock: well - maybe just a bit more :lol:) but am certainly liking the idea more and more of the smoother power delivery available with the tuning.
Loved your silver car Ian and enjoying following where this one goes ...
IanR
Postby IanR » Sat Jan 20, 2018 9:42 pm
KevGoat wrote:I live my power dreams vicariously through threads such as this one ... saves me much $$$, explanations, running, ducking and weaving :roll: :mrgreen: ... Learn a lot from them too. Though they do have some tendency to dissolve resolve :? Not sure I want a whole lot more power from mine ( :shock: well - maybe just a bit more :lol:) but am certainly liking the idea more and more of the smoother power delivery available with the tuning.
Hey Kev, I looked for your build thread...eyes not working and couldnt find it. linky please. Most things in life are not worth doing, I hope I'm saving you lots of cash. The car goes to the paint shop for a few bits n pieces and once the roll bar is back in Ill shoot some video, that should help you decide either way :P
Postby Lokiel » Sat Jan 20, 2018 10:13 pm
Hint: Try the link in KevGoat's signature
Postby KevGoat » Sat Jan 20, 2018 10:44 pm
Lokiel wrote:^
Thanks Lokiel ... the other thread that consistently leads me down the "naughty" path :mrgreen:
IanR
Postby IanR » Sun Jan 21, 2018 9:49 am
Lokiel wrote:^
Thanks...I have managed to find it with your help...
Postby KevGoat » Mon Jan 22, 2018 6:32 pm
Sat outside with a coffee this morning - checked quickly through messages, emails and a few of the threads on the forum on my phone - and ended up reading this thread from start to finish!! :shock: Interestingly, reading it on Tapatalk all the lost Photobucket images show up!! Really is a bloody good read :beer:
Users browsing this forum: No registered users and 157 guests
