NC Ohlins owners question
emilmh
Vehicle: NC - LE
Postby emilmh » Wed Dec 13, 2017 7:53 pm
Hi all,
I have a questions for NC owners who have Öhlins coilovers.
I have bought a second hand set of the coilovers, but according to the installation instructions I am missing a pair of washers I will need.
The seller says they can’t remember getting any bag of washers at all when they bought the kit.
Many install threads also talk about having a few washers left over and apparently it is normal for Öhlins to supply a bit extra hardware.
Q1 Can you remember getting washers with your NC Öhlins kit?
Q2 Did you have any left over washers?
Q3 If you have any left over “t3.2 x 46dia.” can I buy a pair off you?
Thanks
Re: NC Ohlins owners question
Postby Regie » Wed Dec 13, 2017 8:06 pm
I don't recall installing that washer on my Ohlins.
it looks as though the washer will just sit on the shock shaft and bounce up and down
emilmh
Vehicle: NC - LE
Postby emilmh » Wed Dec 13, 2017 10:54 pm
Regie wrote:I don't recall installing that washer on my Ohlins.
I don’t think it can move as it will be held in place by the Öhlins custom aluminium washer (which sits on top of the “shoulder” of the shaft, and shown sitting on top of the bump stop in the diagram), and the factory Mazda bushing (shown as “standard rubber” in the diagram)
Wivvix
Postby Wivvix » Wed Dec 27, 2017 10:35 am
I'd give these guys a call, tell them the part number you're chasing and see if they can help you out or point you in the direction of local support.
https://www.ohlins.com.au/contact_us
Postby Mr Morlock » Wed Dec 27, 2017 12:12 pm
if it's a flat washer( ?) it should be easy to buy- like a suspension fitter or fastener supplier. The washer is probably 1/8 X 1 3/4". The one thing missing is the hole size but not a show stopper.
emilmh
Vehicle: NC - LE
Postby emilmh » Wed Jan 03, 2018 3:32 pm
Yeah, I sent them a message. Unfortunately they don’t seem to care to reply. :?
emilmh
Vehicle: NC - LE
Postby emilmh » Wed Jan 03, 2018 3:35 pm
Mr Morlock wrote:if it's a flat washer( ?) it should be easy to buy- like a suspension fitter or fastener supplier. The washer is probably 1/8 X 1 3/4". The one thing missing is the hole size but not a show stopper.
That was my first plan, but any washer of the diameter I needed had a massive hole in it.
A generous co worker made some for me on their lathe, so I have them now. :D
Wivvix
Postby Wivvix » Fri Jan 05, 2018 2:05 am
emilmh wrote:Yeah, I sent them a message. Unfortunately they don’t seem to care to reply. :?
Lots of businesses are closed or on skeleton staffing until 8 or 15 Jan - it's unfortunate timing but it may take a while for them to follow up.
Users browsing this forum: No registered users and 182 guests
