89 NA6 - drivers side under dash interior light
twr7cx
Postby twr7cx » Wed Dec 06, 2017 8:47 am
The interior light on the lower part of the dashboard on the drivers side of my 89 NA6 isn't working. When I push on it it illuminates so I assume a loose/dodgy connection. What's instructions for removing it to access the back? Given that the car is 28 years old it's better to ask than end up snapping brittle plastic...
lucmor444
Re: 89 NA6 - drivers side under dash interior light
Postby lucmor444 » Wed Dec 06, 2017 8:53 am
It just pops out if you lever it from the middle of a side where the retaining clips are situated.
aka_juffa
Postby aka_juffa » Sun Dec 24, 2017 9:57 pm
Probably some carbon build up on the switch contacts. Should be easy to clean.
Also suggest that you rotate the light 180 degrees, so that you get more light into the cabin.
You can also get more light by getting a led festoon globe from somewhere like jaycar or supercheap.
J
Users browsing this forum: No registered users and 96 guests
