I'm after suggestions for aftermarket seats for my NA. I want something adjustable (no buckets) but something that will hold me a bit better than the factory seats. Something comfortable would also be preferred
Thanks
Droo, how much lower are we talking?droo wrote:There are *heaps* of different options on the market. All depends on your personal taste what you're after. Seats are a very personal thing. One suitable for a short fat driver is not suitable for a tall thin driver and usually not ideal for anyone in between.
For me, these are my fav. I love the shape, i love the fit, and they actually fit in my NA well.
The one on the left are my current seats (only one pictured) and is wearing oem seat rails beneath.
My new replacement (more durable material) on the right (different hoop shape, subtle stitching and design changes and slightly shorter), to be installed.
These hug my thighs, lower back and are a very snug fit for my body. The seatbelt feeds through the holes and is higher then my shoulders, and feeds and retracts smoothly as per oem. The seat doesnt have hard plastics were my head rests in the event of whiplash. This was a consideration based on the previous racing seats i had installed.
Cornering hard you are planted and do not move at all in the seat, and makes for much easier steering (as stupid as that sounds, it is very confidence inspiring on a good mountain road)
I had to put the right hand seat on the left, and the left hand seat on the right, so the adjustment mechanism would clear for the lower seatbelt mount. No big deal, it mated up fine
Has lever recline, which suits fine, although a rotating recliner would be better for more precise positioning if you're one of those super picky/annoying types.
Snug fit in the car, doesnt hit against the door and the base fits, although tight (we like tight), no tearing the material against the carpet to move the seat forward or back but for me, i have it as far back as possible.
Amazingly these are 3-4kg lighter then the oem seats and have had these installed for nearly 4 years, also these sit lower then stock seats (without the foamectomy).
For searching shops or online, get the seat dimensions, and if possible, go to a store that has the seats, bring tools to remove your existing seat and trial fit it on the floor. (make sure there's an additional 2-3" of clearance above the seat to allow for seat rails, and specifically, the ability to recline the seat forward if you have a (fixed) hard top, in order to remove the seat.
If you cant get to a shop, best measure the width of the floor pan, and height from seat mounts to the top of the soft top.
Also the width of the seat shoulders and where the backs of your knees are on the seat and base and compare to the cabin measurements.
Dont forget to factor in the height of the seat rails too, i was fortunate as these bolt up almost perfectly to the oem seat rails. Not all seats will be like this.
I'm running a hard top and there is a height difference vs a soft top. (think the hard top is a smidge lower? i cant recall the specifics)
So how much lower than stock do they sit?droo wrote:yep them's the ones KevGoat!
Fast postage too and is happy to let you pick them up if you live local (bulky big box tho!)
The original seats on the left of my pic, lined up lovely to the rails. Just a few drill holes and bolted through perfectly.
Unfortunately the seats on the right of the pic are very different underneath and will require some thought on how to install them.
