billybunter
Postby billybunter » Sat Oct 21, 2017 5:16 pm
DAY 27 -3 hours
yes- I am actually getting sick of working on this project myself and will be glad when its over :lol:
i knew i couldn't get away with this job so I pulled the rear bar off and got to work giving it a light wet sand with 800 and let dry. wiped it over with grease and wax remover and by then the temp was up to about 18C and perfect for spraying .
gave both sides a bit extra paint too :lol:
sat it aside to dry and afterwards i had to do a few slight repairs to the side brackets which clip the molding to the body. worked out fine
gave it about 3 hours to dry and then slapped it back on the car :lol: and while at it fitted the rear tail lights
yesterday when i was spraying in 24K :lol: and was a bit tight with the paint
side shot
and today
so I think it was worth my time to go back in and do it properly and it wouldn't have happened if I had done it right in the first place :lol: although the wife did say it looked fine -how would she know :lol: but I knew :roll:
billybunter
Postby billybunter » Sun Oct 22, 2017 4:24 pm
DAY 28 3 hours
either side of the windscreen had suffered a bit from sandpaper scuffing so I rubbed both back with 800 and re done them - much neater now
then decided to pull the covers off and the interior was a bit dusty
even picked up a few stray leaves :lol:
the vacuum cleaner tidied it up some
so I decided to mask it all up and go for a dash re-spray too - coat 1.
here's coat 2.
coat 3 and day over
billybunter
Postby billybunter » Mon Oct 23, 2017 5:45 pm
DAY 29 - 3 hours
had a bit of a problem with the right side rail getting it into position and tightening the 3 nuts down - but eventually got there but no picnic :lol: no idea why -just did!
earlier I had re-painted the other plastic parts with vinyl dye
brown/davis roll bar back in
re-sprayed all the boot carpet with carpet dye
then I took a look at this panel
decided this time to rub it out with 2000 wet - rear bar not touched
then use the cutting compound via hand rub
this is going to look really nice when complete BUT too much work to waste on a mazda :lol:
billybunter
Postby billybunter » Mon Oct 23, 2017 8:44 pm
here's a short video I took of the car today
https://youtu.be/oWwNDiRVUls
Postby KevGoat » Mon Oct 23, 2017 8:55 pm
Actually ... looking at that black front lip in the video, I like it :wink:
billybunter
Postby billybunter » Tue Oct 24, 2017 11:17 am
could be all right- time will tell when I get to the final cut all over stage :wink:
now I've been working on this car on a daily basis for about a month and not disturbing the inmates up the back. the breeding season almost over for them and 5 pair continued on and of those 2 pair hatch some good stuff
here's a photo of them - 8 in one nest and 5 in the other worth a cool $5,000 :D alive and not quite so much dead :lol:
so although it was a worthless venture working on the car I will make up for it on sale day in bird land :lol:
billybunter
Postby billybunter » Tue Oct 24, 2017 5:36 pm
DAY 29 -4 hours
started on the drivers side door jam and hand cut the inner areas and fitted the scuff plate
painted the striker plate black and fitted the stereo speaker plus hand cut the inner door area
re- dyed the drivers side door trim
new door to window seal arrived
prior to the fit
fitted
rubber seal fitted and door trim on
drivers seat back in and air bag lead connected. then ignition on to check right side speaker is working ok - all good
right side of car rubbed down with 2000 wet
all good and day over
billybunter
Postby billybunter » Tue Oct 24, 2017 5:48 pm
a couple of closer shots of the cut polish on the car and remember its only been hand cut but not polished yet, i'm really impressed with the results considering I've been clear coating everything for 15 or 20 years
my opinion would be now -the clear is a long way behind it
lucmor444
Postby lucmor444 » Tue Oct 24, 2017 6:54 pm
Two unrelated questions - what sort of vinyl dye do you use and what sort of birds do you breed?
Postby bruce » Tue Oct 24, 2017 8:23 pm
Black
and
Edible !
lucmor444
Postby lucmor444 » Tue Oct 24, 2017 9:07 pm
Bloody expensive snacks (I’d need a few to fill me up).
billybunter
Postby billybunter » Tue Oct 24, 2017 11:06 pm
1. VHT Black Satin
2. The tasty treats are Mutation Gouldian finches. they are the cheepies :lol: . a new mutation is due out at the end of year by another interstate bird breeder and I was told a few days ago the price will be $1800 EACH :lol:
billybunter
Postby billybunter » Wed Oct 25, 2017 12:50 pm
if you have wondered why so many photos this time in the paint thread its probably because its the last time :lol: I've taken a bit of time in doing this and the car runs out of rego in a couple of weeks time
I don't plan to register or drive it again so it will probably have the plates pulled and into the garage and covered over and its over for this car :lol:
meanwhile today I always wondered why I couldn't fit the passenger side seat bolt in and why I only had 7 seat bolts in total and where I lost the other one. well the original hole was factory plugged and it never had a bolt in the first place just a plastic stopper. still threaded of coarse :roll:
rascal
Postby rascal » Wed Oct 25, 2017 1:12 pm
Can't wait for some shots of the car in sunlight.
The current shots under the verandah make it look like its painted beige... :shock:
billybunter
Postby billybunter » Wed Oct 25, 2017 5:56 pm
yeah ... I know :lol: it's suppose to be polar white. I think its from reflections from the verandah. looks a bit whiter straight out the door
