Gladiator
Postby Gladiator » Tue Aug 29, 2017 8:55 pm
I'm sitting here reading this with my mouth agape!!
Postby KevGoat » Tue Aug 29, 2017 9:07 pm
Gladiator wrote:I'm sitting here reading this with my mouth agape!!
Nothing BB does shocks me anymore :roll: :mrgreen:
billybunter
Postby billybunter » Tue Aug 29, 2017 9:54 pm
well I suppose...it has been coming for several months now. :lol: but I don't think I will be laughing too much while I am rubbing out that paint :shock:
Postby 93_Clubman » Wed Aug 30, 2017 11:34 am
BB, sounds like your back has improved - hopefully you can spend more time painting it white this time.
ManiacLachy
Engaged
Postby ManiacLachy » Wed Aug 30, 2017 12:13 pm
This isn't a car, its a canvas. billybunter is Rob Ross.
billybunter
Postby billybunter » Wed Aug 30, 2017 3:34 pm
I was only thinking this over today-while looking inside the door jams you'd have to be a real idiot to destroy a paint job as good as this one and it appears.... I am that idiot! :lol:
back problem is still there so I will have to take this one carefully or it could end up a basket case :shock:
red was probably not going to be a stayer anyway. back 10 years ago I bought a red na from Sydney and paint it yellow :lol:
Postby bruce » Wed Aug 30, 2017 3:52 pm
Should have left it originally white and then put the red paint on my car!
billybunter
Postby billybunter » Wed Aug 30, 2017 4:42 pm
when I get it rubbed back and that will take some time mainly because who put the paint on did it properly :lol: and I can't water blast it off - I will decide if I should go all out and bring out the angle grinder :shock:
Postby 93_Clubman » Wed Aug 30, 2017 5:02 pm
billybunter wrote:I will have to take this one carefully
Not completely a bad thing, as that should help duplicating the quality finish you achieved with the red paint job.
billybunter
Postby billybunter » Wed Aug 30, 2017 5:27 pm
just using the wet rub180 grit its pretty hard work on the cut back, I might go buy some 120 and see how that goes. might be good to score up the surface a bit so I can get through the paint :lol: the go 240 and higher later
the flared in the above photo are not mine -just something I thought about adding if I went back to a re=spray. but it would involve cutting both front and rear guards to add then, plus a bit of drilling too
i'd also have to consider I would not go any bigger than the 15" wheels for ride quality but would go wider wheels. but DEFINATELY would no lower it in any way as i had enough of being in a tip dray in that crappy LOTUS :lol:
Daffy
Postby Daffy » Wed Aug 30, 2017 5:30 pm
ManiacLachy wrote:This isn't a car, its a canvas. billybunter is Rob Ross.
BillyB......... you got to get this squared off mate- you dont want to end up like this!!!!!! :lol: :lol: :shock:
viewtopic.php?t=73496
billybunter
Postby billybunter » Wed Aug 30, 2017 8:14 pm
bit of a stripe removal day and a rub down too
Postby KevGoat » Wed Aug 30, 2017 10:38 pm
billybunter wrote:the flared in the above photo are not mine -just something I thought about adding if I went back to a re=spray. but it would involve cutting both front and rear guards to add then, plus a bit of drilling too
Looks like back to re-spray from the rub down so far. Those flares are a point of no return mod, so definitely require a lot of thought and a plan of where the car's heading before committing.
billybunter
Postby billybunter » Wed Aug 30, 2017 11:07 pm
true, I am known to jump the gun and those flares are like a trip to a dental surgery for root canal :shock: or is it a root canal :lol:
Postby Danny » Thu Aug 31, 2017 9:15 am
OMG what are you doing?
Didn't you just finish a repaint?
Was the paint dry?
