StanTheMan
Postby StanTheMan » Mon Jul 31, 2017 10:39 am
new springs for the high lift cams
The original estimate foir the job was like 3 hrs.
then things escalated dramatically. I could get the old spring out. but couldn't get the new ones in.
ended up taking the head off.
I had a spare head gasket. It ended up taking like 7-8 hrs..... If i didn't have the head gasket I guess I would have put the old springs back in.
new springs a 66 lbs ones. which are what was recommended by the cam manufacturer. No extra power realized at this moment....but it is a fraction smoother down low.
I only managed to get 2 springs in with the head attached to the motor. With the intake ones I just didn't have the right angle or strengths to get them in.
First spring installed with all the sticky engine assembly lube all over it.
lucmor444
Postby lucmor444 » Sun Aug 13, 2017 9:25 pm
Installed my Paco Motorsport Strong Arms. Just got to pull my finger out and install my FM Butterfly brace!
StanTheMan
Postby StanTheMan » Tue Aug 15, 2017 7:57 pm
killing Patchys motor slowly
got yelled at by × peeps today....about the amount of smoke .
looking at options
ManiacLachy
Engaged
Postby ManiacLachy » Tue Aug 15, 2017 11:19 pm
I'm interested to hear how those Paco Strongarms go. They seem a little overkill compared to the other braces, but maybe they're worth it?
Daffy
Postby Daffy » Tue Aug 15, 2017 11:24 pm
StanTheMan wrote:killing Patchys motor slowly
looking at options
Go on then........ fess up- you were pulling a hella handbrake drift shredding and lighting up them back wheels draging off a capella in the western Sydney badlands eh!!!!!
viewtopic.php?t=73496
Postby KevGoat » Thu Aug 17, 2017 1:22 pm
Wife's been nagging me to move the hardtop out of the spare room - it's only been sitting in there under sheets for two and a half years or so ... :roll: Decided to put it back on the car for now. Forgot how good these look with a hardtop fitted.
Gratuitous photo :lol: ...
StanTheMan
Postby StanTheMan » Thu Aug 17, 2017 2:09 pm
the pic of that bonnet.....makes it look like its got a real aggressive bonnet hump. :lol:
Postby KevGoat » Thu Aug 17, 2017 2:36 pm
different angle ... :mrgreen:
speed
Postby speed » Thu Aug 17, 2017 2:39 pm
Yes they look good but i couldn't rationalize keeping mine when it spent so much time in our spare room.
Sent from my SM-A520F using Tapatalk
Postby bruce » Thu Aug 17, 2017 4:50 pm
StanTheMan wrote:got yelled at by × peeps today....about the amount of smoke .
Tell them it blows smoke when you run 50psi.........(in your tires).
StanTheMan
Postby StanTheMan » Thu Aug 17, 2017 5:09 pm
they wouldn have a clue. Some mums in a Porsche & Audi's. Should have been quicker. maybe their Diesel's is killing us.. :lol: :roll:
Chuppa
Postby Chuppa » Sat Aug 19, 2017 9:43 pm
Installed new locked-down mats from mania. Keep forgetting and go to adjust the mat constantly.
Also did the timing properly following my little saga with the CAS last month. Now set at 14°, was previously, um.. off the scale - literally.
‎"We are all self-made. But only the successful will admit it."
3gress
Postby 3gress » Fri Sep 01, 2017 11:27 am
Made up some new brake lines after finally sorting a decent double flare tool.
Never mind the upside down booster...all just mocked up for now.
Hope to drop in block over weekend..
speed
Postby speed » Sat Sep 02, 2017 9:00 pm
Has been a while since I've bought anything for my 5, so last night i pulled the trigger on some bits from Brendan.
3gress
Postby 3gress » Sat Sep 02, 2017 10:17 pm
Lowered engine and trans in to bay in one piece.
Plumbing and wiring in started.
Also picked up a neat carbon lid from speed The front, right hand corner had been cracked ever so slighlty from impact so i set about sanding back to the crack and using epoxy resin to fill in. An aesthetic repair at best , the plan is to spray the carbon finish with plastidip or such to tone it down a little.
Shame really as it is awesome in it's raw carbon cleared finish.
Will give the clear coat a touch up and show some pics.
