Daffy's SE
Daffy
Re: Daffy's SE
Postby Daffy » Sat May 27, 2017 11:19 am
billybunter wrote:you have the same problem as me ...no power on tap :roll: we should both get some power upgrades and get rid of the hairdresser image :lol: red cars are definitely slower :twisted:
speed wrote:That's no round-about.. its a small moon!
You can tell you're really moving when the camera struggles to focus :)
Passengers talking to the V8 drivers be all like......................... :mrgreen:
viewtopic.php?t=73496
Daffy
Re: Daffy's SE
Postby Daffy » Tue Jun 20, 2017 8:29 pm
New headlight bulbs.....
Daffy
Re: Daffy's SE
Postby Daffy » Thu Jun 22, 2017 12:51 pm
New LED's in, the new beam is great and the white light looks good too!
Daffy
Re: Daffy's SE
Postby Daffy » Thu Jun 22, 2017 1:55 pm
Daffy wrote:Some intense Dyno runs have resulted in an underbonet Duck decapitation......
The duck has been re- capitated, its got to wear a neck brace though :?
Re: Daffy's SE
Postby bruce » Thu Jun 22, 2017 2:01 pm
So that flappy thing emits the light of the LEDs? I've never seen anything like it.
Re: Daffy's SE
Postby Magpie » Thu Jun 22, 2017 2:16 pm
No I guess the flappy thing is a heat sink.
Daffy
Re: Daffy's SE
Postby Daffy » Thu Jun 22, 2017 4:24 pm
bruce wrote:So that flappy thing emits the light of the LEDs? I've never seen anything like it.
Magpie wrote:No I guess the flappy thing is a heat sink.
Spot on Magpie :DIY:
Re: Daffy's SE
Postby bruce » Thu Jun 22, 2017 4:59 pm
Gotcha. thanks.
Daffy
Re: Daffy's SE
Postby Daffy » Wed Jun 28, 2017 12:30 pm
Fitted up the new (slightly used Lokiels) SE radiator, with genuine mazdaspeed cap!! Rad should be good for another few thousand ks before a more major upgrade for impending track days- sad foot note though, the dispicable duck head has decapitated again and alas is now lost forever somewhere on the Gold Coast highway...... :frown:
Re: Daffy's SE
Postby Lokiel » Wed Jun 28, 2017 1:06 pm
Lucky it didn't drop into the belts - you could have had a "Deadly Duck" projectile shot out "God knows where" from your engine bay.
The MSM OEM 2-port valve in that spot was reported on several occasions as causing problems when people replaced it with a MBC but left it in place because when the hoses were removed, all that was was holding it in place was its metal bracket, the attached hoses were providing some damping - when the bracket finally snapped due to engine vibration, it was left swinging from the attached harness (guys were leaving the harness attached to the valve to avoid the CEL error).
I used to advise people to remove it altogether and insert a resistor across the harness pins to prevent the CEL error.
Re: Daffy's SE
Postby bruce » Wed Jun 28, 2017 1:24 pm
https://deathproofduck.com/
Get a big duck and screw it to your bonnet!
billybunter
Re: Daffy's SE
Postby billybunter » Wed Jun 28, 2017 2:11 pm
he said DUCK - just in case it's read too quickly :lol:
Daffy
Re: Daffy's SE
Postby Daffy » Wed Jun 28, 2017 9:00 pm
Lokiel wrote:Lucky it didn't drop into the belts - you could have had a "Deadly Duck" projectile shot out "God knows where" from your engine bay.
Fortunately for me, much more brilliant mechanical minds than mine (i.e the brilliant Ben Simpson, has those issues well sorted for me, when he rigged it to pipe the cold rad water to feed in to the rear cylinders...... as for the Dispicable duck head, dare Id say he's well and truly a permanant fixture to the tarmac onthe Gold Coast hwy around Palm beach and definantly not embedded in the drive lines of the problem child!! :roll:
Daffy
Re: Daffy's SE
Postby Daffy » Wed Jun 28, 2017 9:09 pm
billybunter wrote:he said DUCK - just in case it's read too quickly :lol:
bruce wrote:https://deathproofduck.com/
Sorry bruce, but a big duck bolted on the bonnet directly will look a little too weird unless I was towing a campervan........... Billy.......... over the years I have left many an imprint of several "duck screws" on various bonnets!!!!! :lol: :P :wink: :mrgreen: :mrgreen: :mrgreen: VIVA LA DISPICABLE DUCK :BROADY: :BROADY:
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Thu Jun 29, 2017 9:34 pm
She forgot to take her pants off :roll: :P
