jezman wrote:Just for the record ............... checked my new RSRR's, treadware is 200.
Strange! I just checked my new RS-RRs 325/40R17, treadwear is 140
Nuddy wrote:jezman wrote:Just for the record ............... checked my new RSRR's, treadware is 200.
Magpie wrote:Just ran a day with 205/50/15's (AD08R's and AR-1's) on 8" and 6.5" rims respectively.
One of the biggest changes I felt was the difference in unsprung weight. The 8" were 3kg each less than the 6.5" per wheel hence made every single input (steering, brake, throttle) feel very light, almost scary! Whereas the 6.5" rims felt secure and safe like bottle of green ginger wine (green steam) and a six pack of beer on a cold winters night.
Whilst the AR-1's on 6.5" were faster than the AD08R's on 8" rims, I feel that a fresh set of AD08R's on the 8" rims and a little bit of time getting familiar with the setup will see then faster than the AR-1's on 6.5".
Planning on repeating the tests but adding the 7" 6UL's into the mix. These are about the same weight as the 8" but have newer AD08R's on them.
jezman wrote:So ........... put the 140's on the left for Wakefield and the right for SMSP !!
Simples .....................
Danny wrote:Be interesting to swap front and rear, with corrected pressures if necessary, during the day for any changes in over or understeer.
I'm wondering if class changes in USA from 140 to 200 UTOG resulted in some fudging by the tyre manufacturers.
Nuddy wrote:Danny wrote:Be interesting to swap front and rear, with corrected pressures if necessary, during the day for any changes in over or understeer.
Yes the 140s were made in 2015 and the 200s in 2016. I wonder if they are actually any different or if they are just fudging the numbers.
I won't be doing any swapping on Saturday as I will be driving the car to SMSP but the next weekend I'm Trailing to Wakefield so might do a bit of experimenting on the Saturday.
Users browsing this forum: No registered users and 64 guests
