Hi
I am after a set of SE 23mm Front Sway Bar D Bushes, "Nolathane: or similar. My searches have proved futile. Does anyone know who makes them or of a generic.
Steven
SE Sway Bar D BUshes
Re: SE Sway Bar D BUshes
If you haven't already, best to search Mazdaspeed Miata or MSM rather than MX5 SE as this stuff will be US-centric.
<https://www.flyinmiata.com/bushings-brackets-for-na8-and-nb-front-sway-bars.html>
Need to specify Mazdaspeed Miata in Application pull down menu to get the correct set in following: <http://949racing.com/energy-suspension-bushings-miata.aspx>
Btw, <https://www.amayama.com/en> should have the OEM ones if they'll do, but you'll need the part # to order.
Have you tried Superpro? They might not show them in their catalogue, but I'd say they would provide them.
NB front arb bush kits shown are SPF0615-22K & SPF0615-24K, so ask for SPF0615-23K.
