Wheel bearing upgrade path?
davekmoore
Postby davekmoore » Fri Apr 28, 2017 4:28 pm
So, it seems front wheel bearings wear at about the same rate as brake pads when you have a bit of power and 225 R specs.
What is the upgrade path from the standard wheel bearings?
pepejesus
Re: Wheel bearing upgrade path?
Postby pepejesus » Fri Apr 28, 2017 4:41 pm
Barbagallo long: 70.488
Barbagallo short: 58.999
davekmoore
Postby davekmoore » Fri Apr 28, 2017 10:54 pm
Brake ducts, done. Wilwood 6 pots, done. Polymatrix H compound pads, done. Driver ability/training to do less braking, not done.
Flyin' Miata do a "blueprinted" version of standard hubs at less money than an OEM one, but still with ball bearings, so I'm not too hopeful of a solution there.
So I may need to go with the roller bearing ones, even though there's a suggestion they are still in development mode.
Here's hoping.
Hellmun
Postby Hellmun » Sat Apr 29, 2017 12:23 am
Terry Bosnjak makes billet ones for mx5's using tapered roller bearings. Can't rate him and his work high enough. http://www.terrybosnjakengineering.com.au/billett-hubs
They're serious race parts and not cheap though. I was fed up by about the 8th front hubs failure....so I have a set on my car.
davekmoore
Postby davekmoore » Sat Apr 29, 2017 10:08 am
Thank Hellmun.
rascal
Postby rascal » Sat Apr 29, 2017 1:12 pm
Sent you a PM Dave...
Nuddy
Postby Nuddy » Sat Apr 29, 2017 11:56 pm
Is this for all models?
NC 2.5 race/tarmac rally car
NC 2.0 race/tarmac rally car Sold
NB8a Sold
Patrol GUIV TD42tdi for touring and towing
BMW R1200R for daily ride
Return to “MX5 Motor Sport”
