Breaking alternator bracket turbo na
Coote_00
Postby Coote_00 » Mon Apr 24, 2017 11:04 pm
Hi just wanted some suggestions about alternator bracket
Since I've gone turbo I've had to replace it a few times because it brakes or fractures.
Wanted to know if anyone else has had this issue and if there is a way to fix it cheers
Re: Breaking alternator bracket turbo na
Postby NitroDann » Tue Apr 25, 2017 8:50 am
Do you have photos?
Coote_00
Postby Coote_00 » Tue Apr 25, 2017 2:59 pm
Sure do here's a couple that shows what's happening
Postby NitroDann » Tue Apr 25, 2017 5:48 pm
I cant see, is it hosted elsewhere?
Coote_00
Postby Coote_00 » Tue Apr 25, 2017 6:04 pm
Nope can try send them through messenger if you like
3gress
Postby 3gress » Wed Apr 26, 2017 10:05 pm
Hi mate, you could try using a heim joint adjustable tensioner as i did above.
Available from Aeroflow in different lengths such as part no.# AF60-4000 or AF60-4007. Not sure of the part number for the one i have though.
I had to ream out one of the rod end eyelets a little to fit the bolt that attaches to the mounting tang on the water pump but otherwise it works very well for my application.
speed
Re: RE: Re: Breaking alternator bracket turbo na
Postby speed » Fri Jun 23, 2017 9:20 am
3gress wrote:Image
Holy crap. Dan, your engine looks amazing!
Sent from my SM-A520F using Tapatalk
