NB8B diagnostic port issue / car not starting
1600Dave
Postby 1600Dave » Thu Apr 20, 2017 11:42 pm
So, my NB8B is not starting. Cranks fine, but seems to have no spark and injectors not firing.
I rigged up an LED / resistor to check for error codes, plugged it into the diagnostic port and turned the ignition key. LED lights up, but stays lit indefinitely. No blinking, just a solid LED.
I had a water leak into the passenger footwell a few weeks back.
So, my initial thought is water damaged ecu.
Any other suggestions as to why the solid LED / not starting ?
Re: NB8B diagnostic port issue / car not starting
Postby 93_Clubman » Fri Apr 21, 2017 5:13 pm
NB won't start guide: viewtopic.php?t=59479&start=15
NA no start guide: http://wiki.miata.net/tiki-index.php?pa ... tart+Guide
Sounds like it's the ECU, but the NB8B usual suspects to cause various issues are:
Spark plug leads/coil on plug setup;
Cam position sensor;
Crank position sensor;
EGI main relay;
Fuel tank electrical connector;
Fuel pump; &
ECU (if water gets into passenger side floor).
Might be worthwhile resetting/clearing ECU error/fault codes - just disconnect the battery & pump the brake pedal a few times. This full list will help if you're later able to pursue error/fault codes:
viewtopic.php?t=67370
Roadrunner
coyotes after you
Postby Roadrunner » Sat Apr 22, 2017 3:06 pm
Hey Dave,
If you want, shoot me a PM or email, happy to tee up for Lindsay and I to drop around after work one day with my OBDII scanner and see if theres any stored codes.
If it's a dead ECU though, I can't help with that.
MeepMeep
Postby 93_Clubman » Sat Apr 22, 2017 3:36 pm
Using an OBDII reader on it depends on what year NB8B it is as they didn't get an OBDII port until 2002.
1600Dave
Postby 1600Dave » Sun Apr 23, 2017 10:52 pm
Thanks for the kind offer, but its a 2001, no ODBII :frown:
Haven't had a chance to do anything with it yet, just got back from the track day today. I'll have a serious look on Anzac day. No rush, my brother is overseas for a few weeks so I've got his 350Z to drive :mrgreen:
Spark plug leads/coil on plug setup; - tried a spare set , no difference
Cam position sensor; - this or crank was my first thought - it was getting a bit harder to start when hot for a few days before it gave up completely
EGI main relay;
Fuel tank electrical connector; - getting fuel to the fuel rail, just not injecting
Fuel pump; - see above, and has had a new pump recently
ECU (if water gets into passenger side floor). - had an inch or two of water in the passenger footwell with all the rain a few weeks back :oops:
Nevyn72
Postby Nevyn72 » Mon Apr 24, 2017 10:11 am
1600Dave wrote:ECU (if water gets into passenger side floor). - had an inch or two of water in the passenger footwell with all the rain a few weeks back :oops:
Start with the most obvious thing first, pull the ECU and have a look inside the case! :wink:
Postby 93_Clubman » Mon Apr 24, 2017 11:13 am
1600Dave wrote:Fuel tank electrical connector; - getting fuel to the fuel rail, just not injecting
Yeah, check ECU then, given above re fuel not injecting, check EGI main relay & fuel injection fuse.
1600Dave
Postby 1600Dave » Tue Apr 25, 2017 4:49 pm
Thanks for the suggestions, turns out it was a waterlogged ecu / water in the ecu connectors / water somewhere. Amazingly, after drying out for a few days, its running perfectly again :shock: You can see the "high tide" mark on the underfelt, plus see a bit of a a stain on the bottom of the ecu case.
Next step is to take the passenger seat, all carpet and underfelt out of the passenger side to let it dry out thoroughly, investigate why its leaking (it did get a new softtop fitted a few months back, perhaps not fitted properly ?? ). Plus take the ecu out and make sure all connectors / terminals / etc are clean and making proper contact.
Postby bruce » Tue Apr 25, 2017 5:01 pm
That is a dirty flood.
I would dismantle the ECU and give inside a clean.
1600Dave
Postby 1600Dave » Tue Apr 25, 2017 5:07 pm
I was thinking the same. There's a place near me that fixes ecu's, might get them to check it out. I'm hopeless with electrickery.
Water seems to have leaked in from the softtop / rainrail area, run down behind the passenger seat, under the seat and collected in the front footwell. Its usually parked nose downhill, all the water has just run to the front.
Postby 93_Clubman » Wed Apr 26, 2017 1:24 pm
1600Dave wrote:it did get a new softtop fitted a few months back, perhaps not fitted properly?
Reckon the rainrail may not have been refitted, or refitted poorly, or it was refitted in poor condition. Alternatively, the soft top drains either side of the cabin behind the seatbelt towers may be blocked.
Manga_Blue has mentioned a process for the inside of ECUs:
manga_blue wrote:I had a low load intermittent miss that just appeared in the last week or two. This morning I took out the ECU, removed the top and bottom covers, drenched it in electronic circuit board cleaner and then covered all the circuit board and connectors with a mist of INOX MX3. Miss is now gone.
manga_blue wrote:I moved it up into the glovebox a few years ago because it showed some case corrosion from being down on the floor. It never leaked down there but it can get musty. I'm very close to the beach, it's salty here and that doesn't help. If I'd been feeling braver I would have done the full job and dunked it in distilled water, then alcohol and then sprayed it with PCB cleaner, then Inox.
https://mx5cartalk.com/forum/viewtopic. ... start=2445
1600Dave
Postby 1600Dave » Thu Apr 27, 2017 6:30 pm
93_Clubman wrote:Alternatively, the soft top drains either side of the cabin behind the seatbelt towers may be blocked.
We have a winner. Not blocked by the usual accumulation of dirt and gumnuts, but by a "xmas tree" trim clip. A byproduct of having a new softtop fitted ?? Or perhaps just an errant clip from somewhere ??
Regardless, the clip had pretty much completely blocked the passenger side drain. Was a pain to get out as well. Hopefully that's the end of flooding, ecu comes out this weekend for investigation / cleaning of wiring connectors.
Postby 93_Clubman » Fri Apr 28, 2017 12:08 pm
Crikey, the rust! Just saw your pics of ECU cover & footwell area around ECU - good that you've ID'd the cause.
