Gearbox piece on drain plug
Not exactly sure what to call it but when I was changing my transmission fluid today a piece of something was on the magnetic drain plug. Can anyone shed some light on what it could be? It's roughly one cm long and a couple of mm wide.
Re: Gearbox piece on drain plug
That looks like a synchroniser key (sometimes called synchroniser blocker bar). Usually 3 on each synchroniser hub/sleeve
RS2000 wrote:That looks like a synchroniser key (sometimes called synchroniser blocker bar). Usually 3 on each synchroniser hub/sleeve
I presume it's not ideal for the future longevity of my gearbox?
I'll leave that call to a qualified transmission mechanic.
FYI see item 17-243 on attached image of MX5 5 speed gears.
RS2000 wrote:I'll leave that call to a qualified transmission mechanic.
IMG_5 speed MX5.pdf
Had a chat to a mechanic friend this morning who said It's not ideal but to just keep driving it till it craps itself. Lucky 5 speeds are cheap!
Users browsing this forum: No registered users and 61 guests
