Harness mounting backing plates - CAMS compliant
S2-13BT
Postby S2-13BT » Thu Apr 20, 2017 3:57 pm
Anyone know a good source for CAMS compliant harness mounting plates? I notice most of the ones that come up in a google search are FIA spec and are too small to meet CAMS specs.
Or do people just make there own?
Thanks.
rascal
Re: Harness mounting backing plates - CAMS compliant
Postby rascal » Thu Apr 20, 2017 4:09 pm
Just as easy to make your own. It's only a 3inch x 2inch piece of 3mm steel.
S2-13BT
Postby S2-13BT » Thu Apr 20, 2017 8:15 pm
Copy that!
Thanks mate. :beer:
Postby Magpie » Thu Apr 20, 2017 8:58 pm
S2-13BT
Postby S2-13BT » Thu Apr 20, 2017 9:22 pm
Thanks Magpie, I was looking at those but they technically don't meet CAMS specs. One side has to be at least 75mm.
RS2000
Postby RS2000 » Thu Apr 20, 2017 10:25 pm
The Cams requirement used to be based on area. The RI plates are 65x65, which is a greater area than 75x50 !
Ridiculous, if they get knocked back.
Nuddy
Postby Nuddy » Fri Apr 21, 2017 1:02 am
RS2000 wrote:The Cams requirement used to be based on area. The RI plates are 65x65, which is a greater area than 75x50 !
Circular would be best. 74 mm diameter has more area than 65x65 and no sharp corners to initiate tearing.
They need engineers setting the specification.
NC 2.5 race/tarmac rally car
NC 2.0 race/tarmac rally car Sold
NB8a Sold
Patrol GUIV TD42tdi for touring and towing
BMW R1200R for daily ride
Return to “MX5 Motor Sport”
