SP radiator hose replacement.
roshmx5
Postby roshmx5 » Tue Mar 28, 2017 8:56 pm
Hi Members
I want to replace the hose as it is against the intercooler piping.
Who has done this before and can anyone remember what part they bought to do it. Does another vehicles fit better without touching.
I want to replace not just cut and move because it looks a bit melted and soft when heated.
Thanks in advance
Mazda MX5 SP
Re: SP radiator hose replacement.
Postby NitroDann » Tue Mar 28, 2017 9:20 pm
Honestly dude, just leave it its fine.
bmchi
Postby bmchi » Tue Apr 04, 2017 7:23 pm
Ive found this annoying aswell the ic piping just before IM gets super hot from the upper rad hose. Its too hot to touch after a spirited drive.
Im worried this might be fecking around with performance as it might be heatin up the air after the intercooler has done its work and the IAT sensor is also on this piping which may be heating it up and giving the ecu inaccurate readings? Might be why some sps run so rich ableto shed some light?
Ive been out and about trying to find an alternative shape so that it doesnt touch but no luck, ended up wrapping the hose in exhaust wrap where it touches and it seems to have helped a little not so much on long drives.piping is still hot but i can at least touch it
bigdog
King of the kennel
Postby bigdog » Tue Apr 04, 2017 8:51 pm
Mine has an SE top hose to give better clearance:
Sent from my iPhone using Tapatalk Pro
bigdog
King of the kennel
Postby bigdog » Tue Apr 04, 2017 8:55 pm
roshmx5
Postby roshmx5 » Tue Apr 04, 2017 10:34 pm
Thanks guys will try to cut mine let you know how it goes.
Mazda MX5 SP
bmchi
Postby bmchi » Wed Apr 05, 2017 2:46 am
Let us know how u go!
Even a coolant reroute would be difficult just because of where the entry is with the radiator
Postby Lokiel » Wed Apr 05, 2017 10:01 pm
BigDog, are those stainless steel braided lines on your oil filter relocation block?
They look like they rub the chassis and some hoses/wires.
Maybe I'm just being paranoid because I've seen photos where stainless steel braided hoses have sawed through intercooler piping and cut into the chassis, but I'd clad them in split loom to limit this from happening.
bigdog
King of the kennel
Postby bigdog » Wed Apr 05, 2017 11:45 pm
Correct Lokiel. I have insulated them in various spots with rubber, no issues so far and they've been there for many years now
roshmx5
Postby roshmx5 » Fri Apr 07, 2017 8:29 pm
Just to let you know installed another pipe cut it shorter now it isn't hard agains piping. Thanks for your responses.
Mazda MX5 SP
bmchi
Postby bmchi » Mon Apr 24, 2017 7:06 pm
Hey roshmx5 any chance for a few pics?
bmchi
Postby bmchi » Fri Apr 28, 2017 7:04 pm
In case you guys havent seen this.
interesting little article on insulating the return of your intercooler piping
http://www.autospeed.com/cms/article.ht ... n&A=109587
I'd probably use some more purpose made materials for insulating personally but you get the idea.
got a few plans for under bonnet heat management :twisted: :twisted:
just recieved my PTP turbo blanket and plan to get a shielding for the turbo manifold and dump pipe too. :beer:
roshmx5
Postby roshmx5 » Fri Apr 28, 2017 10:13 pm
Will post some pics tomorrow bmchi
Mazda MX5 SP
roshmx5
Postby roshmx5 » Fri Apr 28, 2017 10:17 pm
You can kind of see it here. It is no longer touching the intercooler pipe.
Mazda MX5 SP
bmchi
Postby bmchi » Mon May 01, 2017 6:45 pm
I can see the little gap between the rad hose and IC pipe, looks good!
I'll probably do the same and end up insulating the piping in my plan to reduce heat soak too.
clean engine bay btw! did you paint your reservoir bottles black?
