Gladiators '90 MX5 NA6
Gladiator
Re: Gladiators '90 MX5 NA6
Postby Gladiator » Wed Mar 22, 2017 5:27 pm
I'm actually wondering if I should try & rebuild a "channel" at the bottom corner of the screen there, to direct water out better. I'm just thinking sickaflex or the like.
speed
Postby speed » Wed Mar 22, 2017 5:37 pm
This is going to be epic.
The pock marks look like they've used a centre punch or similar to belt out the panel.
Sent from my old phone using crapatalk
Gladiator
Postby Gladiator » Wed Mar 22, 2017 6:10 pm
speed wrote:This is going to be epic.
Yeah, or a ballpein hammer.
I hope you mean epic good not epic HUGE ?
Gladiator
Postby Gladiator » Wed Mar 22, 2017 7:15 pm
Unfortunately I'm thinking epic HUGE. This is getting way bigger than intended.
speed
Postby speed » Wed Mar 22, 2017 8:20 pm
I meant epic as in good :)
You're going all out now and yes it is a huge undertaking but you know it will be completely rust free and just the way you want it.
Have you given any thoughts to converting to a NB dash?
Might be a little way off but worth considering before you reassemble.
Gladiator
Postby Gladiator » Wed Mar 22, 2017 8:35 pm
I don't actually like the NB dash. Mine is in good nic too so, no I'm happy.
I'm just hoping I haven't bitten too much off. But I suppose, if you don't know, learn. :)
Postby Magpie » Wed Mar 22, 2017 8:48 pm
If you go NB dash you can get rid of that horrible blue NA dash.
Looking forward to seeing the finished job!
The American
Postby The American » Wed Mar 22, 2017 8:55 pm
Given you have access to a welder, thought of fixing the quarter the same way you did the sill? Find a clean shell you can cut that section out of?
Gladiator
Postby Gladiator » Wed Mar 22, 2017 8:57 pm
Magpie wrote:If you go NB dash you can get rid of that horrible blue NA dash.
Look Mark, you're not getting that cluster back, & Rolley is not going to buy it either. Mmwahahaha!!
Gladiator
Postby Gladiator » Wed Mar 22, 2017 8:59 pm
The American wrote:Given you have access to a welder, thought of fixing the quarter the same way you did the sill? Find a clean shell you can cut that section out of?
Yeah, that's the other option. I just don't like being that "Friend in need".
The American
Postby The American » Wed Mar 22, 2017 9:05 pm
Time to buy a mig. Mine is a million years old and cost a few hundred second hand, and I bought a new torch for it, but it has paid for itself many times over.
Gladiator
Postby Gladiator » Wed Mar 22, 2017 9:07 pm
Haha, I have the mig, just not the skills. My welding is ordinary at best.
plohl
Postby plohl » Thu Mar 23, 2017 11:11 am
That's what a grinder and bog is for right?
plohl
Gladiator
Postby Gladiator » Thu Mar 23, 2017 4:46 pm
That's true, but I would know there's a crappy weld under there.
billybunter
Postby billybunter » Fri Mar 24, 2017 12:18 am
those holes in the panel look to me like years ago when i'd drill a hole or in some cases several holes in the damaged area. I would then screw in a screw to lock the panel in and use the panel puller to pull out the dent. use mainly in hard to get places where you hard virtually no access or very little to do the repair.
then again I might be wrong too :lol: :lol:
