Magpie wrote:Should have added you can use something like this to monitor the current draw on the pump.
An ideal addition to any low voltage DC system this digital power meter features real time display of the voltage, current draw, and power consumption. Once running it also stores minimum and maximum voltage, current, and power, together with cumulative amp hours and watt hours consumed by the connected equipment. Suitable for DC systems from 5 to 60 volts and available in versions suitable for inline connection or remote connection with a separate current shunt. Mount the meter using the included snap-in bracket or magnetically on any ferrous surface
https://www.jaycar.com.au/digital-dc-power-meter-with-internal-shunt/p/MS6170
ManiacLachy wrote:Thanks for the info about Deatchwerks! For if/when I needed a new pump, I was looking to them as they're meant to be much quieter than comparable Walbros, but if they don't do the job what good are they?
And man that pisses me off about the nail in the tyre!
Too true Lachy. It was a component of the flyn miata big fuel kit.
See the link below with some feedback on another forum about the Deatchwerks pumps. A truer statment never said as in the Vincent Vega picture![]()
Okibi wrote:Spewin about the Deatschwerks AND the new tyre, I haven't changed fuel pumps YET so happy to get your feedback.
Are you using a fuel pressure regulator?
speed wrote:Bastards! Sorry to hear.
Hope they get what's coming to them.
Sent from my old phone using crapatalk
StanTheMan wrote:spewing about everything.
new pump, new tyre.......
