Issue today
- roshmx5
Issue today
Hi Members today I was having a spirited run in my SP up a mountain and towards the top I noticed my tacho went from 4K up to about 6k and I wasn't on the accelerator. Is this normal or is my clutch on the way out.
Mazda MX5 SP
Re: Issue today
Were you changing down a gear at the time?
- roshmx5
- StanTheMan
Re: Issue today
Check your wiring under the dash if you have an alarm installed. Chances are, it's been butchered & the wiring is affecting it. Wires touching where they are not supposed to be. ask me how I know.
- roshmx5
- JBT
Re: Issue today
roshmx5 wrote:...towards the top I noticed my tacho went from 4K up to about 6k and I wasn't on the accelerator. Is this normal or is my clutch on the way out.
Did the engine note change as well or was this an instrument indication only? If the noise increased as well as the tacho indication, then you probably have a slipping clutch.
- roshmx5
- roshmx5
Users browsing this forum: Google [Bot] and 5 guests
