lolmx5's NA8
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Sun Feb 26, 2017 12:38 pm
ok small update but im excited ahaha,
bought a second hand intake manifold to clean up and spray silver like the heat shield and need to repaint the heat shield again bc since working on the car it got a little scratched up.
ImageUntitled by lol mx5, on Flickr
also decided to get the finish i want from the cam cover i had to take it to someone to do. so $150 later and shes come up like this :)
also picked up a genuine mazda speed Gold oil cap :)
Then i put it all together and i am so happy with the way it turned out :)
have a koyorad 36mm aluminum radiator on order, should be here soon and once thats in it will look so much better
more updates soon :)
lucmor444
Re: lolmx5's NA8
Postby lucmor444 » Sun Feb 26, 2017 12:53 pm
That cam cover looks great and the gold highlights are trick - well done.
smy0003
Re: lolmx5's NA8
Postby smy0003 » Sun Feb 26, 2017 1:34 pm
Looks fantastic!
Sent from my LG-H815
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
jordan.k
Vehicle: NA6 - Turbo
Re: lolmx5's NA8
Postby jordan.k » Sun Feb 26, 2017 2:08 pm
As others have said, cam cover does look great, really suits your sort of resto theme thing you have going on
NA6 Dulux spec
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Sun Feb 26, 2017 3:30 pm
lucmor444 wrote:That cam cover looks great and the gold highlights are trick - well done.
Thanks man, im loving the gold red and polished look
smy0003 wrote:Looks fantastic!
Thanks man, keen for it to be done
jordan.k wrote:As others have said, cam cover does look great, really suits your sort of resto theme thing you have going on
thanks man
speed
Re: lolmx5's NA8
Postby speed » Sun Feb 26, 2017 5:55 pm
Looking good! Who did your cam cover? $150 is a great price.
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Mon Feb 27, 2017 10:01 am
speed wrote:Looking good! Who did your cam cover? $150 is a great price.
Adept metal polishing in wetherill park great guy and proud of his work, really fast picked it up the next day
Re: lolmx5's NA8
Postby Lokiel » Mon Feb 27, 2017 10:28 am
$150 was well-spent on the rocker cover, it looks great.
If you tried this yourself you'd appreciate it even more, it's a HUGE amount of effort by hand and you probably would have stopped well short of the finish you have now.
I'm not a fan of painting manifolds and heat shield covers.
As you found with the heat shield, it gets knocked about a bit through general work on the car and scratches easily, leading to flaking which looks crap.
Consider just cleaning up the new manifold using Alu-brite.
MSMjohn from CR.net "used a wire brush to brighten it up then used some chrome tools to shine it up by rubbing the chrome tools over the surfaces":
See post #3 from http://clubroadster.net/vb_forum/58-forced-induction/27215-mazdaspeed-mx5-denso-321cc-23250-74050-injector-info.html
(best NB fuel injector replacement HowTo on the net).
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Mon Feb 27, 2017 4:30 pm
Lokiel wrote:$150 was well-spent on the rocker cover, it looks great.
Thanks man yea that seems like the better option will look in to it
Re: lolmx5's NA8
Postby Lokiel » Mon Feb 27, 2017 7:09 pm
... just thought I'd throw that idea out there - it's one of things I love about forums, getting alternate views, the more input the better IMO (even if someone tells you "That sucks!" if it really does suck).
Anodising is another option, the dye seeps into the porous finish during the dyeing phase and the sealant seals it, leaving it with a hard, mostly scratch-proof finish.
I still have my original VTCS intake manifold - when I have time, I may try anodising it (the top half). It's a big awkward piece so I'd need 3 containers that I can submerge it completely in.
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Sun Mar 12, 2017 12:04 pm
ok a bit of an update,
finally got my Koyo rad and rad cap, installed the fan and placed all the mounting hardware, pretty straight forward, looks awesome and goes well with the rest of the engine bay nicely,
once that was done drained an replaced old oil and replaced sump plug with a new one and a new washer, (old sump plug had some sort of rubber seal on it, no washer) filled up with new oil ready for a start up soon.
ImageUntitled by lol mx5, on Flickrv
after that i realised that the vacuum hose on the cam cover cracked, was old and hard so replaced it with oem parts. the rest of the hoses felt soft so left them alone.
after that i turned my attention to the interior and striped it down ready for removal. gonna see if i can tackle the heat core and give it a good clean up under it.
got my cluster hood off with out breaking anything so pretty happy with that :)
once heater core is replaced i can fill up with coolant and start her up for the first time in i think months now ahaha, pretty keen for that to happen :)
more updates as i get to doing them
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Mon Mar 13, 2017 6:52 pm
Small update, had a mate come over and help me lift the dash out, came out pretty easy, only thing was had to un pin the new connector for the fog light and a ground wire I added. But besides that it was really easy to come out.
Cleaning it up now but gonna get some felt and foam tape and place it everywhere to minimize rattles in the dash. Have my nb heater core housing ready to go as well. Found that the original heater core seemed to be modified with the pipes and have a slight leak. Could be why my passenger side footwell was wet. I'll upload more pics of the heater core when I can.
Have already taken the Evap system out that was let in with only one bolt ahah, seems like the a/c was defiantly a retro fit. Ac bracket is aftermarket as well, just a plate place on the engine and then the compressor is bolted to that. Only good thing about that is I don't have to find a bolt to stop it leaking oil since it is already there.
More to come
BRG.NA8
Re: lolmx5's NA8
Postby BRG.NA8 » Mon Mar 13, 2017 9:05 pm
So good!
BlackLeaf
Re: lolmx5's NA8
Postby BlackLeaf » Mon Mar 13, 2017 9:43 pm
lolmx5 wrote:...gonna get some felt and foam tape and place it everywhere to minimise rattles in the dash.
Yep, worth the effort. I used some grey foam (from Bunnings, in the tiling section) and double-sided tape for where the dash rests against the windscreen. Was a snug fit but worked well in the end. Also, get some packing foam, or something similar and stuff it in the dash around the ducts and it seems to help with creaks, rattles and noise reduction.
BlackLeaf
R.I.P. 90 Mariner Blue, 12/12/90 - 10/12/15
#321 89 Classic Red, 04/12/15 ->
lolmx5
Re: lolmx5's NA8
Postby lolmx5 » Mon Mar 13, 2017 9:46 pm
Yea that's the exact stuff I was planing to use, didn't think of the dash think tho thanks for that and will defs look into it
Users browsing this forum: No registered users and 149 guests
