Anyone tried the long oil filter on your NA/NB ?
Replacement oil filters for RYCO Z150:
Brand Model
AC-Delco
AC072
AC-Delco
ACO72
Baldwin
B202
Baldwin
T8209
Bosch
0986AF1085
Donaldson
P550158
Fleetguard
LF3369
FSA
C8033
OEM
145623802A
Purolator
L35721
Repco
ROF42
Sakura
C8033
Wesfil
WZ150NM
Wix
51324
Z150 or equivalent Oil Filter
Never put the top up unless the storm has a name.
Re: Z150 or equivalent Oil Filter
I've gone double sized with Z148A, manily because I picked up a box of them for loose change at an Op shop. Same diameter and fitting but twice the length and filter area. You need to grind a bit out of the manifold support braket to fit them, otherwise no problems. As a bonus they're much easier to grip when you undo them.
Users browsing this forum: No registered users and 79 guests
