Muffler delete
roshmx5
Re: Muffler delete
Postby roshmx5 » Thu Feb 23, 2017 4:12 pm
Thanks HKS what I think I will do is just have it straight through and leave it on there for a while. If I don't like it put a hotdog running east west where the muffler is. Thenexhaust place will make a flange so it is bolt on bolt off so if I need to refit OEM I can.
Mazda MX5 SP
Re: Muffler delete
Postby bruce » Thu Feb 23, 2017 5:30 pm
Welded in an electric flap before rear muffler. Open the flap/valve and its opem to atmosphere. closed, it all goes thru muffler as standard.
Re: Muffler delete
Postby hks_kansei » Thu Feb 23, 2017 8:07 pm
roshmx5 wrote:Thanks HKS what I think I will do is just have it straight through and leave it on there for a while. If I don't like it put a hotdog running east west where the muffler is. Thenexhaust place will make a flange so it is bolt on bolt off so if I need to refit OEM I can.
That's a good plan.
Welding in a hotdog after the fact will be dirt cheap too, the welding should only be $50 or so, plus whatever the dog costs.
roshmx5
Re: Muffler delete
Postby roshmx5 » Fri Feb 24, 2017 4:56 pm
Hi members
The muffler delete is done. It's not that loud, doesn't drone at all and the muffler shop took extreme care. Bolt on flange so I can put my other muffler on if I want to go back to original.
Mazda MX5 SP
aka_juffa
Re: Muffler delete
Postby aka_juffa » Mon Feb 27, 2017 10:30 am
Glad it worked out for you.
As Peter has already mentioned in a previous post, those MX-5s with turbos tend to be much quieter. I did a turbo upgrade to a NA6 a few years ago. I had to drive to an exhaust shop with no exhaust from the down pipe back. I was surprised how quite it was. In fact, with the exhaust pulse (I assume caused by the turbo) it sound very much like a WRX at idle.
J
Re: Muffler delete
Postby Magpie » Mon Feb 27, 2017 12:56 pm
