NB SP oil recommendation
roshmx5
Postby roshmx5 » Mon Feb 20, 2017 6:58 pm
Hi guys
What oil would you recommend for my NB SP.
thanks in advance.
Mazda MX5 SP
pepejesus
Re: NB SP oil recommendation
Postby pepejesus » Mon Feb 20, 2017 7:35 pm
Penrite Ten Tenths 'Racing 10' 10w40
Barbagallo long: 70.488
Barbagallo short: 58.999
bear2230
Postby bear2230 » Mon Feb 20, 2017 8:15 pm
Penrite HRP10 full synthetic 10W-50
roshmx5
Postby roshmx5 » Mon Feb 20, 2017 8:34 pm
Thanks guys
Also has any one done the so called $2 mod with the t piece. If so what diameter vacuum line do I need and what are your thoughts did it make a good improvement.
Mazda MX5 SP
Postby 93_Clubman » Tue Feb 21, 2017 12:12 pm
Congrats on the purchase of BULLITT's SP - you might like to add yourself to the SP owners list:
viewtopic.php?f=18&t=41971&start=210
bigdog
King of the kennel
Postby bigdog » Tue Feb 21, 2017 5:20 pm
Can't remember the vacuum hose size - 5mm maybe. Maybe mine went from 130 to 147 rwkw on the dyno with the mod, no real downside. That said mine used to ping terribly under load (before and after mid) so I went with low compression Wiseco pistons when I built the motor.
Sent from my iPhone using Tapatalk Pro
roshmx5
Postby roshmx5 » Tue Feb 21, 2017 6:22 pm
Thanks big dog will do it this weekend have ordered parts. Great to see you had a Dyno result. That's a good gain for a simple mod and a cheap one at that.
Mazda MX5 SP
roshmx5
Postby roshmx5 » Tue Feb 21, 2017 6:23 pm
Richard has helped me out with the parts I need. He has been a champ. It's 3/16 5mm like you said.
Mazda MX5 SP
