So I have an exhaust leak?
turntaker
Postby turntaker » Thu Feb 09, 2017 9:15 pm
Just did an SE muffler swap on my NB but I didn't change the old gasket. Could this possibly cause an exhaust leak.
Here is the video.
https://youtu.be/xEkwU2N64lw
Shadgrind
Re: So I have an exhaust leak?
Postby Shadgrind » Thu Feb 09, 2017 9:37 pm
I left the old gasket on, it looked mullered but it works. Depending on how bad yours is leaking it may 'self seal' with soot, plus not all leaks are MOT fails, only if it makes the car excessively noisy, or there is a danger of carbon monoxide poisoning, and I wouldn't have thought the latter would apply.
turntaker
Re: RE: Re: So I have an exhaust leak?
Postby turntaker » Thu Feb 09, 2017 9:43 pm
Shadgrind wrote:I left the old gasket on, it looked mullered but it works. Depending on how bad yours is leaking it may 'self seal' with soot, plus not all leaks are MOT fails, only if it makes the car excessively noisy, or there is a danger of carbon monoxide poisoning, and I wouldn't have thought the latter would apply.
Yeah true, mine didn't look that bad. Just not sure how loud the SE swap should.be that's why I'm worried. I haven't properly checked yet
project.r.racing
Postby project.r.racing » Fri Feb 10, 2017 5:44 pm
camera should be filming under the car to locate exhaust leak
Postby bruce » Fri Feb 10, 2017 5:58 pm
You are asking US if you have an exhaust leak? Let me check...
Just start the car, put your hand over join, check for a breeze. How simple.
Shadgrind
Postby Shadgrind » Fri Feb 10, 2017 6:20 pm
I checked by using a small piece of tissue held between my index finger and thumb. Hold next to join if it moves, then it's leaking.
