back to tuning
bruce wrote:What's a stock 1.6 make? 100kw at engine/around 70kw at wheels?
speed wrote:If you had 85kw to begin with and it measured 74kw atw, isn't that only a 13% loss from the driveline?
Forget the numbers for a sec. I thought you said that it feels like more power now with the work you've done.
Maybe there is something different with the settings of the dyno or the ambiant air temp etc.
Will be interesting to see the increase with the tune on the MS.
speed wrote:You had 106kw. Dam, that must have gone well.
IIRC you've done porting and compression since.
You still using those same cams?
Cus has made me want to check my accell enrichment.
StanTheMan wrote:currently its still getting very lean when off he throttle decelerating. seeing numbers like 20:1 occasionally for very short periods. It seems to strat bubbling or over run from 17: or over
StanTheMan wrote:While cruising & accelerating in traffic I'm getting high 11's not low 10 anymore. this is all below 5000 rpm.
StanTheMan wrote:I'm curious about how far I can take the timing. Ive not noticed any pinging. But I'm going deaf. hearing loss is not a good thing when tuning.
StanTheMan wrote:all in all. the new ones seem a lot less agressive from what I recall. Could also be my tuning the timing on the cams.
StanTheMan wrote:I do still have a temperature sensor which I can install right on the CAI.... I just have to calibrate the sensor itself. I have no idea what car it is from.
