Speed's boosted NA6
Daffy
Re: Speed's boosted NA6
Postby Daffy » Sat Feb 04, 2017 10:22 am
speed wrote:Thanks Daffy. I was asking about your beanie. How long did it last?
The beanie is an epman brand, just the cheapo- I had intended to replace it a while ago. Its still going and doing what its ment to 20,000 or so k's on, but I'll be giving the engine bay a big cleanup soon and want to pretty it up a bit. its been off and on a few times, so some of the fiber is looking dusty and brittle. Looking at either an areoflow or most likely a Golebys.
viewtopic.php?t=73496
speed
Postby speed » Sat Feb 04, 2017 2:28 pm
Thanks Daffy.
Ok, so now I have my turbo clocked some more and the IC pipe lines up perfectly.
The only draw back is that it's closer to the coolant hose. Still has some clearance but I would have preferred a bit more.
Ah modified cars, there's always a compromise.
I've tightened the clamps as much as they will go and basically hung off it to test.
Turbo beanie is also on.
At $36 including post, I don't expect that it will last long but wanted it for some reassurance.
I do think that it cleans things up a little but as long as my bonnet doesn't melt :)
Nevyn72
Postby Nevyn72 » Sat Feb 04, 2017 2:32 pm
speed wrote:Turbo beanie is also on.
Relax mate, the bonnet will only melt enough to provide sufficient cooling air flow, it's self regulating that way! :mrgreen:
speed
Re: RE: Re: Speed's boosted NA6
Postby speed » Sat Feb 04, 2017 2:38 pm
Haha. Maybe you should remove your heat shield to save some weight.
Selene isn't exactly light. Oops!
speed
Postby speed » Sat Feb 04, 2017 4:34 pm
Postby bruce » Sat Feb 04, 2017 4:44 pm
How does the waste gate actuator fit through the beanie?
speed
Postby speed » Sat Feb 04, 2017 5:08 pm
bruce wrote:How does the waste gate actuator fit through the beanie?
I cut a hole in the beanie and feed it through. Flap still works fine with the beanie in place.
StanTheMan
Postby StanTheMan » Sat Feb 04, 2017 10:27 pm
So is it drivable?
speed
Postby speed » Sat Feb 04, 2017 11:05 pm
StanTheMan wrote:So is it drivable?
Yep. Hope to get registered later in the week. Still need 2 fittings welded in behind the air filter but I'm hoping I can get that done Wednesday or Thursday.
Also needs a new alterator belt, soft top fitted, grill refitted and a better hose from the ICV to the TBI.
speed
Postby speed » Sun Feb 05, 2017 1:15 pm
Today I modded my grille to alloy the IC piping to run through it and fitted it up, made up a new hose for the ICV/TBI and removed my alterator belt ready to replace once I get a new one.
Am considering painting the front of my intercooler black with white sharks teeth for laughs.
speed
Postby speed » Mon Feb 06, 2017 7:45 pm
Wiped down the soft top area pre fitting my NB roof.
speed
Postby speed » Wed Feb 08, 2017 2:04 pm
Today I fitted a new alternator belt and my NB soft top.
Still waiting on some parts pre rego.
ManiacLachy
Engaged
Postby ManiacLachy » Wed Feb 08, 2017 2:54 pm
The car is really coming along now Speed!
speed
Postby speed » Thu Feb 09, 2017 12:52 pm
Thanks Lachy.
Dann's catch can comes with AN fittings for all the hoses.
There was also a 90 degree male to male 6AN fitting.
I was sure that this was to be able to plumb a hose from the catch can directly after the air filter but there was no female fitting supplied which confused me a little.
Rather than bother Dann or over think it I purchased one off eBay.
Today I will be drilling holes in my 3 inch stainless joiner so that I can fit the 6 orb fitting and the 25mm fitting for the BOV.
I'm a day behind as there was a stuff up with the fittings so now hoping to get rego on saturday.
Since I'll be visiting my welder today or tomorrow I also thought best I dodgy up a heat shield so he can do that and the fittings in one go.
Have a go at my heatshield.
I'm dubbing it the mad max shield.
She might not look pretty and yes I did beat the sh*t out of my stock shield.
2 layers of Steele with fiberglass in between. Once welded, ground and painted black, she will look good enough for me.
Nevyn72
Postby Nevyn72 » Thu Feb 09, 2017 1:36 pm
speed wrote:Dann's catch can comes with AN fittings for all the hoses.
I'm pretty sure that's meant to replace the PCV on the intake side of the cam cover. (The PCV is no longer required with the way the Dann-can is plumbed)
That's where it's used with my setup with the prototype catch-can. :wink:
