Na8 fuel delivery problem...
Red_Bullet
Vehicle: NA8 - Supercharged
Re: Na8 fuel delivery problem...
Postby Red_Bullet » Sat Feb 04, 2017 10:47 pm
93_Clubman wrote:
Chicane8 wrote:(the workshop did) took just two weeks for it to rub through and short out.
Electrical short in the fuel tank - Oops!
Yeah, I thought that too. Is heatshrink fuel proof? I would be sceptical to say the least.
But then again, I was surprised when I learned that electric fuel pumps are actually inside the tank. Then I figured some smart ass engineer figured it is ok. Coming from an electrical background I was surprised. Just didn't sound right to me. Having now accepted that this is how it is I'm quite happy that cars don't go KA_BOOM all the time.
Postby manga_blue » Sun Feb 05, 2017 9:01 am
You need fuel, a spark and oxygen to start a fire. There's not enough oxygen inside a fuel tank to allow it to happen.
speed
Re: RE: Re: Na8 fuel delivery problem...
Postby speed » Sun Feb 05, 2017 9:15 am
manga_blue wrote:You need fuel, a spark and oxygen to start a fire. There's not enough oxygen inside a fuel tank to allow it to happen.
That's what I was thinking but figured someone would say that there is an amount of oxygen each time the fuel cap is opened.
Postby 93_Clubman » Sun Feb 05, 2017 10:25 am
Red_Bullet wrote:Is heatshrink fuel proof?
Fuel rated heatshrink (& wiring & connectors) is available.
Postby manga_blue » Sun Feb 05, 2017 11:53 am
Modern cars have a non-vented fuel cap and tank, a flap on the filler neck and some sort of fuel vapour capture/release system, typically based on a charcoal canister. Together these form a system designed to maintain O2 levels in the tank below dangerous levels.
Postby manga_blue » Sun Feb 05, 2017 2:02 pm
... which is all fine as long as you don't worry too much about TWA800.
Postby 93_Clubman » Sun Feb 05, 2017 2:59 pm
manga_blue wrote:maintain O2 levels in the tank below dangerous levels.
Another reason not to leave the car running when refueling! :mrgreen:
