When the valve in my people mover clogged I ordered a few from here:
http://www.ebay.com.au/itm/Windscreen-Washer-Pipe-Hose-Tube-One-Way-Non-Return-Valve-/162006251041
Dirty cheap and they arrived fairly quickly.
Weeping windscreen washer nozzles
Re: Weeping windscreen washer nozzles
I ended up removing the valves entirely and it solved the problem.
Re: RE: Re: Weeping windscreen washer nozzles
ManiacLachy wrote:I'm having this problem with my NitroDann washer bottle. Do the photos from Droo's posts work for anyone else, for me they're dead. Has anyone else successfully fixed the issue? Care to take a photo for me?
I'll try what I think he's describing and see how I go, otherwise, I'll go look for an aquarium shop I suppose
Just confirming that droos pics don't work for me either.
I've not put water in my ND bottle yet but curious to know what fixes for you, if valve or reposition.
Can anyone tell me where the one way valve is in a na6, as I've not noticed it?
- ManiacLachy
- Engaged
I found these on m.net. NA and NB. They're for US cars, but I think you can mentally flip them the right way
I haven't gotten a solution yet, I tried quickly to pull the check valves, but they were stuck on tight and I was in a rush. I'll have another go this weekend.
Thanks Lachy, now I know where to look.
