Postby Magpie » Mon Jan 09, 2017 3:36 pm
There is an argument that the CAMS approved foam on my cage behind the seat could be removed. There is a bit of room and the seat is not hard up against it, the photo angle is deceiving.
I will find out next weekend if the padding is needed down the right hand side of the roll bar.
11. PROTECTIVE PADDING
11.1 HELMET AND HEAD PROTECTION:
(a) For vehicles subject of a safety cage structure as per Article 3; Application: where the helmet of an occupant could come into contact with the safety cage structure and/or any safety cage bar that is directly above or to the side of the helmet of an occupant, protective padding shall be fitted to that area, which complies with:
(i) International Competition and below, FIA standard 8857-2001, type A (see FIA Technical List No 23 “Roll Cage Padding Homologated by the FIA”); or
(ii) For National Competitions and lower, SFI specification 45.1. For each 1st Category vehicle, the use of SFI specification 45.2 for the head rest is permitted.
Where it can be demonstrated that the fitment of protective padding unduly hampers the occupants’ ability to operate the vehicle in a safe manner, the requirement for padding will be negated in the immediate area of concern at the discretion of the Chief Scrutineer.
11.2 BODY PROTECTION: Where the body of an occupant could come into contact with the safety cage, it is recommended that flame retardant padding be fitted. FIA standard 8857-2001 or SFI specification 45.1 padding
