SS11 NC2
SS11
SS11 NC2
Postby SS11 » Fri Dec 23, 2016 10:00 pm
So after missing having a MX5 collecting dust in the Garage I have decided to get another, and after research decided to look to NC's... this time round put focus on low k, and. Service history, found one that ticked the boxes and booked flight to SA to do the deal..
Stock standard 2009 nc2 one owner..
Already ordered and received RX8 wiper stork, to add adjustable time for intermittent wipers and short antenna
Planning coil overs to lower, exhaust,and polishing and cleaning and Bluetooth kit to start...
NC2-- Tein Flex, Tomei Headers, GWR Super Q , RPF1, ECUtek Race Rom...
SS11
Re: SS11 NC2
Postby SS11 » Thu Jan 05, 2017 10:30 pm
Big Plans, Little Steps...
Started out with simplest and mod, disconnected the annoying beeper that chimes to remind you to take key out of ignition when door is open.. simple case of removing the three screws under the cover that goes around the steering column by the indicator and wiper stalk and unclip the correct 2 wire connector.. this stops the beeps when door open and key in door, but not the lights on ignition off....
Also replaced the Wiper Stalk to the RX8 unit, with time adjustable intermittent... direct plug out, plug in, Awesome!..
Fitted Xcarlink Bluetooth module, also direct plug in, to give Bluetooth Streaming Audio and Handsfree (Why did Mazda not fit this feature as standard!), so far unit seems to work well, but have only spent 5 minutes with it...
Gave car full claybar treatment and polish, made a lot of difference and glad to find no paint surprises, still need to give interior a birthday... also replaced Battery (original still in from 2009!), air filter and wiperblades for good measure..
Ordered Headers and hoping to buy used Tein Flex from forum member in couple weeks!...
luzinit
Re: SS11 NC2
Postby luzinit » Thu Jan 05, 2017 10:53 pm
Couldn't resist staying away from here could you?
How do you find it compared to your old SE?
SS11
Re: SS11 NC2
Postby SS11 » Fri Jan 06, 2017 12:06 am
No, always the same when I sell a MX5, hard to find a different car to fill the same spot and tick the same boxes!...
had a few MX5's now, and find it hard to compeer NA to NB and NC, they all have their pros and cons.. I liked the SE, but really happy with the NC.. I always overlooked the NC and thought it was heavier and more disconnected than it is... I was looking for a NB or NA and thought to be fair I should consider looking at NC and seeing the market changing (used ND's entering market and dropping NC prices) as well as NA's going up ( maybe supply and demand, with increased appeal of cheap reg?) and NB somewhere in between, NC made sense on paper and was surprised happy with drive... still plenty of early design in NC and I believe Mazda did a great job of retaining the sprit... so waffle over, simple answer to your question, is I like the NC, but different to SE...
Sent from my iPad using Tapatalk
LiteIsRite
Re: SS11 NC2
Postby LiteIsRite » Fri Jan 06, 2017 7:12 am
Clean example! If you don't mind me asking, what sort of money did it cost?
”How you get there is the worthier part.” - Shepherd Book, Firefly
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
david_syd_au
Re: SS11 NC2
Postby david_syd_au » Fri Jan 06, 2017 9:29 am
Nice work.
The RX-8 wiper stack swap was the first change I made after buying an NC2 last year.
It was very cheap of Mazda to not include that as standard!
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
jaycrab
Re: SS11 NC2
Postby jaycrab » Fri Jan 06, 2017 2:54 pm
SS11 wrote:Big Plans, Little Steps...
Any more info on this? How do you identify the correct connector? I'd love to do this on mine.
SS11
Re: SS11 NC2
Postby SS11 » Fri Jan 06, 2017 3:29 pm
The picture above (with ignition barrel) shows the connector disconnected... there are only two in the area and it is the top most one.... there is a tab at the top of the connector to push in before pulling the connector out...
SS11
Re: SS11 NC2
Postby SS11 » Fri Jan 06, 2017 3:30 pm
Sorry release tab is at bottom of connector ...
AndyT
Re: SS11 NC2
Postby AndyT » Mon Jan 09, 2017 12:32 pm
Well done on the purchase, got one the same. Keen to know where you purchased the Xcarlink Bluetooth module and the RX8 intermittent wiper stalk. Agree these are a cheap exclusion on what was close to a %50K new car!!
SS11
Re: SS11 NC2
Postby SS11 » Mon Jan 09, 2017 1:52 pm
Bluetooth direct from xcarlink http://www.xcarlink.com/
Rx8 stalk of eBay...
easy
SS11
Re: SS11 NC2
Postby SS11 » Thu Jan 12, 2017 6:56 pm
Not real patient, and once I get a idea I struggle to find my hold button.... googled the buggery out of Tomei and could only find good comments, including from Brian Goodwin on his website and forum.. based on this and that Tomei is a Japanese company making parts for Japanese cars (both car and company RHD) and that the headers and compatable to bolt up to OEM mid pipe, I took a gamble... if I was more patient I likely would have waited till feb when mx5 parts have shipment of Goodwin, but I am not blessed...
Ordered on Amazon and they arrived today, $620 delivered to door....
They look great, with fantastic welds and I believe and hope o2 sensors go in positions they have provided with bungs in place.. time will tell if I brought a expensive wall hanging or a great set of headers, plan to find out time weekend...
SS11
Re: SS11 NC2
Postby SS11 » Fri Jan 13, 2017 7:39 am
SS11
Re: SS11 NC2
Postby SS11 » Sun Jan 15, 2017 12:41 pm
SS11
Re: SS11 NC2
Postby SS11 » Sun Jan 15, 2017 12:47 pm
Tomei headers fitted! PITA getting the factory "headers" out, but all in all with stop /start to play babysitter, and one trip to repo to get o2 sensor remover socket, all done in good time.... supplied sensor positions seem ok and no error codes... only had chance to take on short drive but certainly feels like more torque, yay
