While trying to fix it with a new bit of hose I broke the nipple that connects the water hose off.
How do I repair that?
StanTheMan wrote:If I drilled a hole into it at the front, then run a hose from there to the idle valve?
StanTheMan wrote:StanTheMan wrote:If I drilled a hole into it at the front, then run a hose from there to the idle valve?
Let me just clarify
Drill a hole on the flat surface.
Attach hose over new hole which I've drilled but it also covers the existing hole.
Secure hose with a screw on clamp
Then run hose to attach to the idle controll valve
Let me just clarify
