I have a large piece of tan leather I will be using, make sure you have enough for 2 doors beforehand
Place your door piece upside down against the leather and draw out an outline about 1" from the edge, this allows plenty of room to staple it to the other side.
Then cut out the shape with a good sharp pair or scissors
Begin folding the leather over and stapling it place, ensure to keep the door central so you don't run out of room on the other side.
While pulling the other side over, ensure to pull tight and avoid creasing, you can continually check it as you go along.
When it comes to the raised notches, cut In the door and fold either side of the notch and cut out the centre piece.
For the corners, like before, make several cuts into the leather, and staple each piece.
After the door card has been covered and pulled tight, you can then cut the holes for the door handle and arm rest.
This is what you should end up with In the end
I didn't cut the arm rest holes as I am not using them
Here is what they look like with a new dash, carpet and seat
