speed
Re: RE: Re: billybunters - from a bmw z4 to a mx5 se
Postby speed » Sat Dec 24, 2016 5:32 pm
Danny wrote:How much flexing of the bumpers can the paint handle before it flakes off? Or is it as good 2 pac with the flexible primer you applied?
If painting in 2pak you also use flexi prime. It's the primer that prevents cracking and flaking.
Billy, your car is really looking good :)
billybunter
Postby billybunter » Sat Dec 24, 2016 6:21 pm
danny
well the first paint handled two trips to the top end with 25,000 klm in total and 6 years on the car so it held well. I am actually using two plastic primers -one via aerosol and the more expensive stuff called lesonal 1k plastic primer which is sprayed directly on the plastic and pretty expensive at $55 litre
speed
if you keep this up -you will have to come up for a test drive :wink: well its no-where near perfect BUT it is way ahead of the white car so I can say it has been worth the trouble :)
its only when you start adding stuff back on its starting to show its true colour :lol:
billybunter
Postby billybunter » Sat Dec 24, 2016 6:24 pm
I hit this bit with a 1500 wet and dry sandpaper then hand rubbed :lol: after that I got back to the guard :shock: :roll: this will give a rough idea of the shine I think I will get in the end
billybunter
Postby billybunter » Sat Dec 24, 2016 7:23 pm
rear wing -red or black?
The American
Postby The American » Sat Dec 24, 2016 7:56 pm
I'd vote red over black! Looking good!
smy0003
Postby smy0003 » Sat Dec 24, 2016 10:36 pm
The American wrote:I'd vote red over black! Looking good!
Agreed on both counts.
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Postby Okibi » Sat Dec 24, 2016 10:50 pm
I concur !
speed
Postby speed » Sat Dec 24, 2016 11:08 pm
I'd be happy just seeing it in the flesh.
You've done a lot of quality work in such a short time frame.
Can't wait to see more pics of the entire car once she's all back together and buffed.
Just out of curiosity, what product are you using to dye the dash?
billybunter
Postby billybunter » Sat Dec 24, 2016 11:29 pm
vht vinyl dye. worked well before so back to using it again
billybunter
Postby billybunter » Sun Dec 25, 2016 12:17 am
I think it would be a waste of time going back here next year - i'd be over the limit. might try a run to cairns qld instead
billybunter
Postby billybunter » Sun Dec 25, 2016 7:23 pm
what a great day! when I got up and peered through the back window of the house -much to my delight the old man in the red suite had just finished spray painting my rear spoiler and sitting it next to the car
so that saved me a bit of work and his painting was about equal to mine....... :D well I thought mine was a tad better but one must not complain about gifts :lol: so a good day was had by all
I also hope all the members had a very good xmas day too :beer:
billybunter
Postby billybunter » Mon Dec 26, 2016 6:20 pm
colour coded the door handles today ....RED. I had plans on black but went for the safer option.
after that fitted the additional molding to the bottom of the rear bar and back on the car
billybunter
Postby billybunter » Mon Dec 26, 2016 6:22 pm
both my left and right soft top drain holes were blocked with leaves/dirt grime etc. they were still draining but very slow. today was the perfect opportunity to give then a clean out
billybunter
Postby billybunter » Mon Dec 26, 2016 6:25 pm
next up the centre consul was completely re-dye again so it is now good to go. plus the body line belt now looks much neater sitting around the rear top half. no more chipped or scratch paint to hide
billybunter
Postby billybunter » Mon Dec 26, 2016 6:29 pm
last move for the day was to bolt the soft top in position. easier said than done and it took a bit of aligning to get the 3 bolt holes to line up. I will continue on this part of the - put them back on - tomorrow
overall I am pretty happy how things are going and I think I have a SE far ahead of what I started with a few weeks ago :wink:
