What to do with 12 days and no work.... car projects
1. Brake Booster delete
2. Hook up VBox Lite to Haltech CAN
3. Install 8kg rear springs
4. Make car able to meet noise limits at Sandown
5. Finish seat brackets
6. Tidy wiring up (job when dash out for booster delete).
Job 1 - This is a big one and long in the making also seals the cars fate. Will not be able to use manual bias in some events, but... many thanks to Zossy1 for making this possible. This setup has already proved itself, whilst it maybe a little heavier this is balanced out by the fact that brakes can be adjusted on the 'fly'.
Look familiar... test mounted on the shell to get a plan developed to install into the blue car. May have to get some custom braided lines made up to replace the hard lines, makes routing easier.
DSCN3673 by
Eipeip, on Flickr
Issues... The pedal box was installed on a stripped out car that did not have the fuse box or harness going through the fire wall. I still have both of these
Mock up of where the bottles will be located.
DSCN3678 by
Eipeip, on Flickr
What has to be removed from the blue car... Note airbox already removed
DSCN3672 by
Eipeip, on Flickr
Must thank Steampunk for the gift of this tool, allows you to turn the handle and get into tight spaces to remove nuts! No need to move the whole ratchet, which can be done as well!
DSCN3668 by
Eipeip, on Flickr
Current pedal spacing
DSCN3674 by
Eipeip, on Flickr
New setup, a little closer
DSCN3675 by
Eipeip, on Flickr
Job 2 - Hook up VBox Lite to Haltech CAN
This was a failure. It would appear that the VBox is acting like a termination device on the CAN. Whilst it does not show any data on the VBox it prevents data going to the IQ3. The IQ3 needs to be the last device on the CAN
Will contact VBox support and see if there is a solution, however this was a nice to have.
