instrument glass
trader
instrument glass
Postby trader » Sun Dec 11, 2016 2:06 pm
Does anyone know if the instrument glass(plastic) from an NB cluster will fit the NA one?
Thanks
NB SE, NA 1.8.
slug_dub
Re: instrument glass
Postby slug_dub » Sun Dec 11, 2016 3:19 pm
The clear plastic bit might be the same between both models but it is plastic welded to the black face that covers the actual gauges and that is different because of the electronic odometer in NB's.
You could cut off the clear part and swap them, the edge where you would need to glue will be covered by the binnacle cover... but I don't think that'd be a better way to go than finding a good NA one. :)
smy0003
Postby smy0003 » Sun Dec 11, 2016 4:39 pm
Buy my KG Works cluster cover?
Sent from my LG-H815
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
